[PATCH 0/6] Proposes fixes for RTEMS Tester documentation page
Gedare Bloom
gedare at rtems.org
Mon Apr 6 04:26:12 UTC 2020
These don't apply cleanly anymore. Can you rebase them? I will also
provide a couple comments to the patches.
On Sun, Mar 22, 2020 at 10:18 AM <clrrm at isep.ipp.pt> wrote:
> From: Cláudio Maia <clrrm at isep.ipp.pt>
> This set of patches proposes several fixes for RTEMS Tester
> documentation. Namely:
> - Text was reviewed and improved for clarity;
> - References to 'sparc-rtems5-run' command and 'erc32-run' were removed
> from the documentation page. Now, the example uses 'erc32-sis' instead.
> Further references to 'sparc-rtems5-run' are still in other parts of the
> documentation (Sections 10.2 and 10.3) which also need to be updated in
> the future.
> In addition to this, I will send another patch in a different email
> which removes 'erc32-run.ini' from 'rtems-tools' repo as this BSP
> configuration uses 'sparc-rtems5-run'.
> Cláudio Maia (6):
> user/tools/tester.rst: Cleans up text
> user/tools/tester.rst: Removes wrong reference to GDB break points
> user/tools/tester.rst: Clarifies the need of --rtems-tools in
> rtems-test command line
> user/tools/tester.rst: Rephrase last sentence
> user/tools/tester.rst: Removes example using 'sparc-rtems5-run'
> user/tools/tester.rst: Removes text references to 'erc32-run' and
> replaces the example with 'erc32-sis'
> user/tools/tester.rst | 191 ++++++++++++++++++++----------------------
> 1 file changed, 93 insertions(+), 98 deletions(-)
> 2.17.1
> devel mailing list
> devel at rtems.org
