sis broken on freebsd 12
Mon Apr 6 04:52:38 UTC 2020
On 2020-04-06 14:48, Sebastian Huber wrote:
> On 06/04/2020 04:35, Chris Johns wrote:
>>> configure:3033: checking whether the C compiler works
>>> configure:3055: gcc -O2 -pipe -fbracket-depth=1024
>>> -I/usr/home/joel/rtems-cron-5
>>> /rtems-source-builder/rtems/build/tmp/sb-1002/5/rtems-sparc/home/joel/rtems-cron
>>> -5/tools/5/include    conftest.c  >&5
>>> gcc: error: unrecognized command line option '-fbracket-depth=1024'
>>> configure:3059: $? = 1 >
>>> $ gcc --version
>>> gcc (FreeBSD Ports Collection) 9.2.0
>>> Copyright (C) 2019 Free Software Foundation, Inc.
>> The OS compiler is llvm so something is picking up gcc. The OS
>> compiler is preferred over a port. What is your path?
> Could this be also the problem in
> http://devel.rtems.org/ticket/3817
> We don't have a gcc from the ports collection installed in our VM. I can
> build all tools (using the GNU sed).
It could be the same thing and may explain what is happening. If it is
nice catch.
