[PATCH 6/6] user/tools/tester.rst: Removes text references to 'erc32-run' and replaces the example with 'erc32-sis'
Mon Apr 6 04:40:52 UTC 2020
On Sun, Mar 22, 2020 at 10:18 AM <clrrm at isep.ipp.pt> wrote:
> From: Cláudio Maia <clrrm at isep.ipp.pt>
>  user/tools/tester.rst | 12 +++++-------
>  1 file changed, 5 insertions(+), 7 deletions(-)
> diff --git a/user/tools/tester.rst b/user/tools/tester.rst
> index 5147f3d..5548ad9 100644
> --- a/user/tools/tester.rst
> +++ b/user/tools/tester.rst
> @@ -62,11 +62,9 @@ You can list the available BSP testers with:
>            project.
>  Some of the BSPs may appear more than once in the list. These are aliased BSP
> -configurations that may use a different back-end. An example is the erc32 BSP.
> -There is the erc32 tester which uses the GDB back-end and the
> -``erc32-run`` tester which uses the ``run`` command for erc32. We will show
> -how to use :program:`rtems-test` command with the erc32 BSP because it is easy
> -to build an use.
> +configurations that may use a different back ends. We will show how to use
delete 'a'
> +:program:`rtems-test` command with the erc32 BSP because it is easy to build
> +and use.
>  .. _BuildingRTEMSTests:
> @@ -267,8 +265,8 @@ BSP build tree:
>  .. code-block:: none
>      $ ~/development/rtems/test/rtems-tools.git/tester/rtems-test \
> -             --log=log_erc32_run \
> -             --rtems-bsp=erc32-run \
> +             --log=log_erc32_sis \
> +             --rtems-bsp=erc32-sis \
>                   sparc-rtems5/c/erc32/testsuites/samples
>      RTEMS Testing - Tester, 5.not_released
>      [ 1/13] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  | sparc/erc32: base_sp.exe
> 2.17.1
> devel mailing list
> devel at rtems.org
