[PATCH 1/1] bsps: Deletes erc32-run.ini
Gedare Bloom
gedare at rtems.org
Mon Apr 6 04:58:50 UTC 2020
Pushed, thanks for the cleanup
On Sun, Mar 22, 2020 at 10:33 AM <clrrm at isep.ipp.pt> wrote:
> From: Cláudio Maia <clrrm at isep.ipp.pt>
> tester/rtems/testing/bsps/erc32-run.ini | 38 -------------------------
> 1 file changed, 38 deletions(-)
> delete mode 100644 tester/rtems/testing/bsps/erc32-run.ini
> diff --git a/tester/rtems/testing/bsps/erc32-run.ini b/tester/rtems/testing/bsps/erc32-run.ini
> deleted file mode 100644
> index 3dc5f60..0000000
> --- a/tester/rtems/testing/bsps/erc32-run.ini
> +++ /dev/null
> @@ -1,38 +0,0 @@
> -# RTEMS Tools Project (http://www.rtems.org/)
> -# Copyright 2015 On-Line Applications Research Corporation (OAR).
> -# All rights reserved.
> -# This file is part of the RTEMS Tools package in 'rtems-tools'.
> -# Redistribution and use in source and binary forms, with or without
> -# modification, are permitted provided that the following conditions are met:
> -# 1. Redistributions of source code must retain the above copyright notice,
> -# this list of conditions and the following disclaimer.
> -# 2. Redistributions in binary form must reproduce the above copyright notice,
> -# this list of conditions and the following disclaimer in the documentation
> -# and/or other materials provided with the distribution.
> -# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> -# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> -# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> -# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
> -# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> -# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> -# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> -# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> -# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> -# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> -# POSSIBILITY OF SUCH DAMAGE.
> -# The erc32 BSP
> -[erc32-run]
> -bsp = erc32
> -arch = sparc
> -tester = %{_rtscripts}/run.cfg
> -bsp_run_cmd = %{rtems_tools}/%{bsp_arch}-rtems%{rtems_version}-run
> 2.17.1
> devel mailing list
> devel at rtems.org
