PC BSP bset failure
Joel Sherrill
joel at rtems.org
Mon Apr 6 23:31:20 UTC 2020
Hi
I haven't investigated them all but the pc fails to build libbsd and I
thought this one should work given recent attention:
50/1916] Compiling freebsd/lib/libc/rpc/clnt_dg.c
[ 51/1916] Compiling freebsd/sbin/sysctl/sysctl.c
../../freebsd/sbin/sysctl/sysctl.c:72:10: fatal error: machine/pc/bios.h:
No such file or directory
#include <machine/pc/bios.h>
compilation terminated.
Waf: Leaving directory
`/home/joel/rtems-work/rtems-source-builder/rtems/build/rtems-libbsd-v816a2f912f414f39467a6be901a96159f806c01d-x86_64-linux-gnu-1/rtems-libbsd-816a2f912f414f39467a6be901a96159f806c01d/build/i386-rtems5-pc686-default'
Build failed
-> task in 'objs02' failed with exit status 1 (run with -v to display more
information)
shell cmd failed: /bin/sh -ex
/home/joel/rtems-work/rtems-source-builder/rtems/build/rtems-libbsd-v816a2f912f414f39467a6be901a96159f806c01d-x86_64-linux-gnu-1/do-build
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200406/ce88da1b/attachment.html>
