AW: PC BSP bset failure
Jan.Sommer at dlr.de Jan.Sommer at dlr.de
Tue Apr 7 06:50:02 UTC 2020
Hi Joel,
Thanks, yes the changes have not been merged yet to the 5-freebsd-12 branch.
I am about to prepare the next version of the patch set.
Cheers,
   Jan
Von: devel [mailto:devel-bounces at rtems.org] Im Auftrag von Joel Sherrill
Gesendet: Dienstag, 7. April 2020 01:31
An: rtems-devel at rtems.org; Jan Sommer
Betreff: PC BSP bset failure
Hi
I haven't investigated them all but the pc fails to build libbsd and I thought this one should work given recent attention:
  50/1916] Compiling freebsd/lib/libc/rpc/clnt_dg.c
[  51/1916] Compiling freebsd/sbin/sysctl/sysctl.c
../../freebsd/sbin/sysctl/sysctl.c:72:10: fatal error: machine/pc/bios.h: No such file or directory
 #include <machine/pc/bios.h>
compilation terminated.
Waf: Leaving directory `/home/joel/rtems-work/rtems-source-builder/rtems/build/rtems-libbsd-v816a2f912f414f39467a6be901a96159f806c01d-x86_64-linux-gnu-1/rtems-libbsd-816a2f912f414f39467a6be901a96159f806c01d/build/i386-rtems5-pc686-default'
Build failed
 -> task in 'objs02' failed with exit status 1 (run with -v to display more information)
shell cmd failed: /bin/sh -ex  /home/joel/rtems-work/rtems-source-builder/rtems/build/rtems-libbsd-v816a2f912f414f39467a6be901a96159f806c01d-x86_64-linux-gnu-1/do-build
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200407/0ca11b60/attachment.html>
