[PATCH v2 3/3] score: Delete RTEMS_DECLARE_GLOBAL_SYMBOL()
Sebastian Huber
Tue Apr 7 08:57:11 UTC 2020
Delete unused RTEMS_DECLARE_GLOBAL_SYMBOL().
Update #3799.
cpukit/include/rtems/score/basedefs.h | 20 --------------------
testsuites/sptests/spmisc01/init.c | 7 -------
2 files changed, 27 deletions(-)
diff --git a/cpukit/include/rtems/score/basedefs.h b/cpukit/include/rtems/score/basedefs.h
index 0a4ac8e415..67250773e7 100644
--- a/cpukit/include/rtems/score/basedefs.h
+++ b/cpukit/include/rtems/score/basedefs.h
@@ -359,26 +359,6 @@
#define RTEMS_DEFINE_GLOBAL_SYMBOL( _name, _value )
#endif
- * @brief Defines a global symbol with the specified name in the specified
- * section.
- * The name must be a valid designator. The alignment of the symbol depends on
- * the current location counter of the section.
-#if defined(__GNUC__)
- #define RTEMS_DEFINE_GLOBAL_SYMBOL_IN_SECTION( _name, _section ) \
- __asm__( \
- ".pushsection \"" _section "\"\n" \
- "\t.globl " \
- RTEMS_XSTRING( RTEMS_SYMBOL_NAME( _name ) ) "\n" \
- RTEMS_XSTRING( RTEMS_SYMBOL_NAME( _name ) ) ":\n" \
- "\t.popsection\n" \
-#else
- #define RTEMS_DEFINE_GLOBAL_SYMBOL_IN_SECTION( _name, section )
-#endif
* @brief Returns the value of the specified integral expression and tells the
* compiler that the predicted value is true (1).
diff --git a/testsuites/sptests/spmisc01/init.c b/testsuites/sptests/spmisc01/init.c
index 8d713c4219..9090069973 100644
--- a/testsuites/sptests/spmisc01/init.c
+++ b/testsuites/sptests/spmisc01/init.c
@@ -99,10 +99,6 @@ RTEMS_DECLARE_GLOBAL_SYMBOL(a_global_symbol);
RTEMS_DEFINE_GLOBAL_SYMBOL(a_global_symbol, 0xabc);
-RTEMS_DECLARE_GLOBAL_SYMBOL(a_second_symbol);
-RTEMS_DEFINE_GLOBAL_SYMBOL_IN_SECTION(a_second_symbol, ".rtemsroset.dummy");
RTEMS_STATIC_ASSERT(0 != 1, zero_neq_one);
static int array[3];
@@ -215,9 +211,6 @@ static void Init(rtems_task_argument arg)
rtems_test_assert(printflike_func("%i", 0) == 56);
rtems_test_assert(obfuscate_variable(63) == 63);
rtems_test_assert((uintptr_t)a_global_symbol == 0xabc);
- p = a_second_symbol;
- RTEMS_OBFUSCATE_VARIABLE(p);
- rtems_test_assert((uintptr_t)p != 0);
rtems_test_assert(RTEMS_ARRAY_SIZE(array) == 3);
rtems_test_assert(sizeof(zero_length_array_struct) == 4);
container_of();
2.16.4
