[PATCH v2 3/3] score: Delete RTEMS_DECLARE_GLOBAL_SYMBOL()
Gedare Bloom
gedare at rtems.org
Tue Apr 7 15:05:16 UTC 2020
This looks better to me.
On Tue, Apr 7, 2020 at 2:57 AM Sebastian Huber
> Delete unused RTEMS_DECLARE_GLOBAL_SYMBOL().
> Update #3799.
> cpukit/include/rtems/score/basedefs.h | 20 --------------------
> testsuites/sptests/spmisc01/init.c | 7 -------
> 2 files changed, 27 deletions(-)
> diff --git a/cpukit/include/rtems/score/basedefs.h b/cpukit/include/rtems/score/basedefs.h
> index 0a4ac8e415..67250773e7 100644
> --- a/cpukit/include/rtems/score/basedefs.h
> +++ b/cpukit/include/rtems/score/basedefs.h
> @@ -359,26 +359,6 @@
> #define RTEMS_DEFINE_GLOBAL_SYMBOL( _name, _value )
> #endif
> - * @brief Defines a global symbol with the specified name in the specified
> - * section.
> - * The name must be a valid designator. The alignment of the symbol depends on
> - * the current location counter of the section.
> -#if defined(__GNUC__)
> - #define RTEMS_DEFINE_GLOBAL_SYMBOL_IN_SECTION( _name, _section ) \
> - __asm__( \
> - ".pushsection \"" _section "\"\n" \
> - "\t.globl " \
> - RTEMS_XSTRING( RTEMS_SYMBOL_NAME( _name ) ) "\n" \
> - RTEMS_XSTRING( RTEMS_SYMBOL_NAME( _name ) ) ":\n" \
> - "\t.popsection\n" \
> -#else
> - #define RTEMS_DEFINE_GLOBAL_SYMBOL_IN_SECTION( _name, section )
> -#endif
> * @brief Returns the value of the specified integral expression and tells the
> * compiler that the predicted value is true (1).
> diff --git a/testsuites/sptests/spmisc01/init.c b/testsuites/sptests/spmisc01/init.c
> index 8d713c4219..9090069973 100644
> --- a/testsuites/sptests/spmisc01/init.c
> +++ b/testsuites/sptests/spmisc01/init.c
> @@ -99,10 +99,6 @@ RTEMS_DECLARE_GLOBAL_SYMBOL(a_global_symbol);
> RTEMS_DEFINE_GLOBAL_SYMBOL(a_global_symbol, 0xabc);
> -RTEMS_DECLARE_GLOBAL_SYMBOL(a_second_symbol);
> -RTEMS_DEFINE_GLOBAL_SYMBOL_IN_SECTION(a_second_symbol, ".rtemsroset.dummy");
> RTEMS_STATIC_ASSERT(0 != 1, zero_neq_one);
> static int array[3];
> @@ -215,9 +211,6 @@ static void Init(rtems_task_argument arg)
> rtems_test_assert(printflike_func("%i", 0) == 56);
> rtems_test_assert(obfuscate_variable(63) == 63);
> rtems_test_assert((uintptr_t)a_global_symbol == 0xabc);
> - p = a_second_symbol;
> - RTEMS_OBFUSCATE_VARIABLE(p);
> - rtems_test_assert((uintptr_t)p != 0);
> rtems_test_assert(RTEMS_ARRAY_SIZE(array) == 3);
> rtems_test_assert(sizeof(zero_length_array_struct) == 4);
> container_of();
> 2.16.4
> devel mailing list
> devel at rtems.org
