[PATCH] 5/bsps: Remove build set for atsamv
Sebastian Huber
Tue Apr 7 13:46:45 UTC 2020
On 07/04/2020 15:43, Joel Sherrill wrote:
> This just means it doesn't have a bset. It doesn't mean it works. It
> still is present in libbsd.
> It will just now fail when someone performs the same steps by hand. I
> don't see removing the bset as the solution.
> I do not propose removing it from libbsd or the bsets. There needs to
> be a mechanism like the tcfg logic to disable specific tests for
> specific BSPs in libbsd.
Yes, and my approach to this problem would be to change the libbsd build
system to something similar to the new RTEMS build system once it is
integrated. This is not something which can be fixed before the RTEMS 5
release from my point of view.
