[PATCH] 5/bsps: Remove build set for atsamv
Tue Apr 7 13:43:59 UTC 2020
This just means it doesn't have a bset. It doesn't mean it works. It still
is present in libbsd.
It will just now fail when someone performs the same steps by hand. I don't
see removing the bset as the solution.
I do not propose removing it from libbsd or the bsets. There needs to be a
mechanism like the tcfg logic to disable specific tests for specific BSPs
in libbsd.
--joel
On Tue, Apr 7, 2020 at 8:40 AM Sebastian Huber <
> It is not possible to build libbsd with the standard settings of this
> BSP.  The BSP is also highly configurable and it is unlikely that the
> RSB built configuration runs on a custom board.
>  rtems/config/5/bsps/atsamv.bset | 10 ----------
>  1 file changed, 10 deletions(-)
>  delete mode 100644 rtems/config/5/bsps/atsamv.bset
> diff --git a/rtems/config/5/bsps/atsamv.bset
> b/rtems/config/5/bsps/atsamv.bset
> deleted file mode 100644
> index 4bde317..0000000
> --- a/rtems/config/5/bsps/atsamv.bset
> +++ /dev/null
> @@ -1,10 +0,0 @@
> -%define mail_single_report 1
> -%define with_rtems_bsp atsamv
> -%define rtems_target   arm-rtems5
> -%define rtems_host     %{rtems_target}
> -5/rtems-arm
> -5/rtems-kernel
> -5/rtems-libbsd
> -5/rtems-packages
> 2.16.4
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200407/d288c27f/attachment.html>
