[PATCH RSB] bare/glib-2.39.3-1: Add patches to suppress string literal warning
Gedare Bloom
gedare at rtems.org
Tue Apr 7 19:19:28 UTC 2020
On Tue, Apr 7, 2020 at 12:03 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> On Tue, Apr 7, 2020 at 11:12 PM Joel Sherrill <joel at rtems.org> wrote:
>> On Tue, Apr 7, 2020 at 12:35 PM Gedare Bloom <gedare at rtems.org> wrote:
>>> I'm not sure what error this is fixing, is there a ticket open for the warning?
>> No idea on this.
>>> Is there a fix for the warning besides squelching it?
>> I think these are the warnings that are build failures on some hosts. <I think>
> I get these errors on Fedora30:
> ../../glib-2.39.3/gio/gdbusauth.c: In function '_g_dbus_auth_run_server':
> ../../glib-2.39.3/gio/gdbusauth.c:1297:11: error: '%s' directive argument is null [-Werror=format-overflow=]
> 1297 | debug_print ("SERVER: WaitingForBegin, read '%s'", line);
> The added patches fix this.
I see, this is a build error with newer gcc toolchains? Is this only
affecting qemu-couverture? What version of gcc is your host using? Can
you try to find if there is a ticket open in glib or if this is fixed
in newer version, so we can track for the upstream fix?
If newer versions of glib fix it, consider bumping the version? Is
qemu-couverture up-to-date?
>>> How permanent is that gitlab? Should we just pluck these patches ourselves?
>> That's gnome.gitlab.org and per the link at https://www.gnome.org/gnome-3/source/,
>> it appears to be the official GNOME git repository. I think I would trust it.
>> --joel
>>> On Tue, Apr 7, 2020, 7:59 AM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
>>>> bare/config/devel/glib-2.39.3-1.cfg | 4 ++++
>>>> 1 file changed, 4 insertions(+)
>>>> diff --git a/bare/config/devel/glib-2.39.3-1.cfg b/bare/config/devel/glib-2.39.3-1.cfg
>>>> index 9ff7af5..bd5770a 100644
>>>> --- a/bare/config/devel/glib-2.39.3-1.cfg
>>>> +++ b/bare/config/devel/glib-2.39.3-1.cfg
>>>> @@ -14,6 +14,10 @@
>>>> %hash sha256 glib-%{glib_version}.tar.xz d9fa6c9aa645a5e688a3bb29013bb83801b19ee767d99e33ff52e004e1cc5fc8
>>>> +#Patch to supress string literal warning
>>>> +%patch add glib https://gitlab.gnome.org/GNOME/glib/commit/0817af40e8c74c721c30f6ef482b1f53d12044c7.patch
>>>> +%patch add glib https://gitlab.gnome.org/GNOME/glib/commit/566e1d61a500267c7849ad0b2552feec9c9a29a6.patch
>>>> # The GLib build instructions. We use 2.x.x Release 1.
>>>> 2.21.1
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
>>> devel mailing list
>>> devel at rtems.org
