[PATCH RSB] bare/glib-2.39.3-1: Add patches to suppress string literal warning
Vijay Kumar Banerjee
vijay at rtems.org
Tue Apr 7 20:06:23 UTC 2020
On Wed, Apr 8, 2020 at 12:49 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Tue, Apr 7, 2020 at 12:03 PM Vijay Kumar Banerjee <vijay at rtems.org>
> wrote:
> > On Tue, Apr 7, 2020 at 11:12 PM Joel Sherrill <joel at rtems.org> wrote:
> >> On Tue, Apr 7, 2020 at 12:35 PM Gedare Bloom <gedare at rtems.org> wrote:
> >>> I'm not sure what error this is fixing, is there a ticket open for the
> warning?
> >> No idea on this.
> >>> Is there a fix for the warning besides squelching it?
> >> I think these are the warnings that are build failures on some hosts.
> <I think>
> > I get these errors on Fedora30:
> > ../../glib-2.39.3/gio/gdbusauth.c: In function '_g_dbus_auth_run_server':
> > ../../glib-2.39.3/gio/gdbusauth.c:1297:11: error: '%s' directive
> argument is null [-Werror=format-overflow=]
> > 1297 | debug_print ("SERVER: WaitingForBegin, read '%s'",
> line);
> > The added patches fix this.
> I see, this is a build error with newer gcc toolchains?
Yes
> Is this only
> affecting qemu-couverture?
yes, it's only affecting qemu-couverture
> What version of gcc is your host using?
$>gcc --version
gcc (GCC) 9.2.1 20190827 (Red Hat 9.2.1-1)
> Can
> you try to find if there is a ticket open in glib or if this is fixed
> in newer version, so we can track for the upstream fix?
> I found these patches from the bugzilla issue:
https://bugzilla.gnome.org/show_bug.cgi?id=761550
If newer versions of glib fix it, consider bumping the version?
I'm getting these errors from glib-2.48.2 as well.
> Is
> qemu-couverture up-to-date?
No, and it fails to build. There are issues in qemu-couverture as well.
> >>> How permanent is that gitlab? Should we just pluck these patches
> ourselves?
> >> That's gnome.gitlab.org and per the link at
> https://www.gnome.org/gnome-3/source/,
> >> it appears to be the official GNOME git repository. I think I would
> trust it.
> >> --joel
> >>> On Tue, Apr 7, 2020, 7:59 AM Vijay Kumar Banerjee <vijay at rtems.org>
> wrote:
> >>>> bare/config/devel/glib-2.39.3-1.cfg | 4 ++++
> >>>> 1 file changed, 4 insertions(+)
> >>>> diff --git a/bare/config/devel/glib-2.39.3-1.cfg
> b/bare/config/devel/glib-2.39.3-1.cfg
> >>>> index 9ff7af5..bd5770a 100644
> >>>> --- a/bare/config/devel/glib-2.39.3-1.cfg
> >>>> +++ b/bare/config/devel/glib-2.39.3-1.cfg
> >>>> @@ -14,6 +14,10 @@
> >>>> %hash sha256 glib-%{glib_version}.tar.xz
> d9fa6c9aa645a5e688a3bb29013bb83801b19ee767d99e33ff52e004e1cc5fc8
> >>>> +#Patch to supress string literal warning
> >>>> +%patch add glib
> https://gitlab.gnome.org/GNOME/glib/commit/0817af40e8c74c721c30f6ef482b1f53d12044c7.patch
> >>>> +%patch add glib
> https://gitlab.gnome.org/GNOME/glib/commit/566e1d61a500267c7849ad0b2552feec9c9a29a6.patch
> >>>> # The GLib build instructions. We use 2.x.x Release 1.
> >>>> 2.21.1
> >>>> _______________________________________________
> >>>> devel mailing list
> >>>> devel at rtems.org
> >>>> http://lists.rtems.org/mailman/listinfo/devel
> >>> devel mailing list
> >>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200408/dc7407f8/attachment.html>
