Need help to run a smp testsuite on erc32 with multi core
Gedare Bloom
gedare at rtems.org
Tue Apr 7 19:33:26 UTC 2020
On Tue, Apr 7, 2020 at 1:30 PM Richi Dubey <richidubey at gmail.com> wrote:
> Hey everyone,
> Can someone please help me out with running a smp testsuite on erc32(which uses SPARC instruction set). I tried using sis, but the -m option for multi core doesnt seem to work, as the sis readme says: "-m cores : Enable the number of cores (2 - 4) in a leon3 or RISC-V multi-processor system." and that sis supports:
What do you mean it doesn't seem to work? What was broken/how do you
know it was broken?
How did you configure/build rtems?
How did you invoke sis?
What is the output of running sis?
> " sis is capable of emulating four different processor systems:
> ERC32 ERC32 SPARC V7 processor
> LEON2 LEON2 SPARC V8 processor
> LEON3 LEON3 SPARC V8 processor
> RISC-V RISC-V (RV32IMACFD) processor "
> So if sis does not support multi-core for erc32 systems, what should I use to run a smp program on erc32?
> devel mailing list
> devel at rtems.org
