Need help to run a smp testsuite on erc32 with multi core
Richi Dubey
richidubey at gmail.com
Wed Apr 8 17:17:38 UTC 2020
Dear Dr. Bloom,
I understand. I would be more specific from next time.
When I ran sis with no multi-core option, the result came out same as when
I ran it with -m 2 option, (To simulate the executable with 2 cores). And
on reading sis manual, I understood it didn't support erc32
multiprocessing, now I know the reason was because erc32 is a single core
processor.
I built erc32 on SPARC - RTEMS with --enable-smp option enabled.
On trying to run the debugger, sparc-rtems5-gdb [file], It doesnt not
support the command " tar sim -erc32" anymore(from
https://devel.rtems.org/wiki/Debugging/sis) and I didn't know how to set a
simulator as a target.
Thank you.
On Wed, Apr 8, 2020 at 1:03 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Tue, Apr 7, 2020 at 1:30 PM Richi Dubey <richidubey at gmail.com> wrote:
> > Hey everyone,
> > Can someone please help me out with running a smp testsuite on
> erc32(which uses SPARC instruction set). I tried using sis, but the -m
> option for multi core doesnt seem to work, as the sis readme says: "-m
> cores : Enable the number of cores (2 - 4) in a leon3 or RISC-V
> multi-processor system." and that sis supports:
> What do you mean it doesn't seem to work? What was broken/how do you
> know it was broken?
> How did you configure/build rtems?
> How did you invoke sis?
> What is the output of running sis?
> > " sis is capable of emulating four different processor systems:
> > ERC32 ERC32 SPARC V7 processor
> > LEON2 LEON2 SPARC V8 processor
> > LEON3 LEON3 SPARC V8 processor
> > RISC-V RISC-V (RV32IMACFD) processor "
> > So if sis does not support multi-core for erc32 systems, what should I
> use to run a smp program on erc32?
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200408/210402e6/attachment-0001.html>
