[PATCH] Tests for pthread_getcpuclockid method
Eshan Dhawan eshandhawan51 at gmail.com
Tue Apr 7 19:49:15 UTC 2020
On Wed, Apr 8, 2020 at 12:59 AM Gedare Bloom <gedare at rtems.org> wrote:
> Is there a ticket for psxgetcpuclockid? Linked from the psx compliance
> ticket?
> On Tue, Apr 7, 2020 at 5:28 AM Eshan dhawan <eshandhawan51 at gmail.com>
> wrote:
> If so the commit message should include
> Updates #nnnn.
> >  testsuites/psxtests/Makefile.am               | 10 ++
> >  testsuites/psxtests/configure.ac              |  1 +
> >  testsuites/psxtests/psxgetcpuclockid01/init.c | 96 +++++++++++++++++++
> >  .../psxgetcpuclockid01/psxgetcpuclockid01.doc | 19 ++++
> >  .../psxgetcpuclockid01/psxgetcpuclockid01.scn |  4 +
> >  5 files changed, 130 insertions(+)
> >  create mode 100644 testsuites/psxtests/psxgetcpuclockid01/init.c
> >  create mode 100644
> testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.doc
> >  create mode 100644
> testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.scn
> > diff --git a/testsuites/psxtests/Makefile.am
> b/testsuites/psxtests/Makefile.am
> > index 1f9e4233ec..ffadff16e7 100755
> > --- a/testsuites/psxtests/Makefile.am
> > +++ b/testsuites/psxtests/Makefile.am
> > @@ -462,6 +462,16 @@ psxgetattrnp01_CPPFLAGS = $(AM_CPPFLAGS)
> $(TEST_FLAGS_psxgetattrnp01) \
> >         $(support_includes) -I$(top_srcdir)/include
> >  endif
> > +if TEST_psxgetcpuclockid01
> > +psx_tests += psxgetcpuclockid01
> > +psx_screens += psxgetcpuclockid01/psxgetcpuclockid01.scn
> > +psx_docs += psxgetcpuclockid01/psxgetcpuclockid01.doc
> > +psxgetcpuclockid01_SOURCES = psxgetcpuclockid01/init.c
> > +psxgetcpuclockid01_CPPFLAGS = $(AM_CPPFLAGS)
> $(TEST_FLAGS_psxgetcpuclockid01) \
> > +       $(support_includes)
> > +endif
> >  if TEST_psxgetrusage01
> >  psx_tests += psxgetrusage01
> >  psx_screens += psxgetrusage01/psxgetrusage01.scn
> > diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/
> configure.ac
> > index 139787cccb..c509086abc 100644
> > --- a/testsuites/psxtests/configure.ac
> > +++ b/testsuites/psxtests/configure.ac
> > @@ -91,6 +91,7 @@ RTEMS_TEST_CHECK([psxfile01])
> >  RTEMS_TEST_CHECK([psxfile02])
> >  RTEMS_TEST_CHECK([psxfilelock01])
> >  RTEMS_TEST_CHECK([psxgetattrnp01])
> > +RTEMS_TEST_CHECK([psxgetcpuclockid01])
> >  RTEMS_TEST_CHECK([psxgetrusage01])
> >  RTEMS_TEST_CHECK([psxglobalcon01])
> >  RTEMS_TEST_CHECK([psxglobalcon02])
> > diff --git a/testsuites/psxtests/psxgetcpuclockid01/init.c
> b/testsuites/psxtests/psxgetcpuclockid01/init.c
> > new file mode 100644
> > index 0000000000..b2b26339d2
> > --- /dev/null
> > +++ b/testsuites/psxtests/psxgetcpuclockid01/init.c
> > @@ -0,0 +1,96 @@
> > + *  @file
> > + *  @brief Test suite for getcpuclockid methods
> > + * SPDX-License-Identifier: BSD-2-Clause
> > + * Copyright (C) 2020 Eshan Dhawan
> > + * Redistribution and use in source and binary forms, with or without
> > + * modification, are permitted provided that the following conditions
> > + * are met:
> > + * 1. Redistributions of source code must retain the above copyright
> > + *    notice, this list of conditions and the following disclaimer.
> > + * 2. Redistributions in binary form must reproduce the above copyright
> > + *    notice, this list of conditions and the following disclaimer in
> the
> > + *    documentation and/or other materials provided with the
> distribution.
> > + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> > + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
> TO, THE
> > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> > + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
> CONTRIBUTORS BE
> > + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> > + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> > + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> > + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
> IN
> > + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
> OTHERWISE)
> > + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
> OF THE
> > + * POSSIBILITY OF SUCH DAMAGE.
> > +#define _GNU_SOURCE
> is this necessary?  why?
I have taken this base from other test suite so don't exactly know its
relevance.
I will remove it
if its presence is unlikely
> > +#ifdef HAVE_CONFIG_H
> > +#include "config.h"
> > +#endif
> > +#include <errno.h>
> > +#include <pthread.h>
> > +#include <stdint.h>
> > +#include <rtems/test.h>
> > +#include <sys/utsname.h>
> > +#include <unistd.h>
> > +#include <errno.h>
> > +#include <sched.h>
> > +#include <rtems/score/todimpl.h>
> > +#include <rtems/score/threadimpl.h>
> > +#include "tmacros.h"
> Are all of the above headers necessary?
> I have also planned to add clock_getcpuclockid() in the same test suite so
they might be needed.
> > +const char rtems_test_name[] = "PSXGETCPUCLOCKID 1";
> > +/* Forward declaration to avoid warnings */
> > +rtems_task Init(rtems_task_argument ignored);
> > +void *test_task(void);
> > +/* test_task function begins */
> > +void *test_task()
> > +  int r;
> > +  clockid_t cid;
> > +  r = pthread_getcpuclockid(pthread_self(), &cid);
> add spaces after (  and before )
> > +  if(r)
> formatting: if ( r ) {
> > +    printf("pthread_getcpuclockid : 0x%d", r );
> space after (
> Probably want a \n also.
> > +  rtems_test_assert( r == 0 );
> > +  return NULL;
> > +/* init test function begins */
> > +  TEST_BEGIN();
> > +  test_task();
> This isn't a "task" the function name is a bit misleading.
I will change the name to a more understandable form.
> > +  TEST_END();
> > +  rtems_test_exit(0);
> > +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> > +#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
> > +#define CONFIGURE_MAXIMUM_TASKS 1
> > +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
> > +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> > +#include <rtems/confdefs.h>
> > diff --git
> a/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.doc
> b/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.doc
> > index 0000000000..bfe9c7b9ff
> > --- /dev/null
> > +++ b/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.doc
> > @@ -0,0 +1,19 @@
> > +#  COPYRIGHT (c) 2020
> > +#  On-Line Applications Research Corporation (OAR).
> > +# SPDX-License-Identifier: BSD-2-Clause
> > +This file describes the directives and concepts tested by this test set.
> > +test set name:  psxgetcpuclockid 1
> > +Directives:
> > +  Pthread_getcpuclockid()
> > +Concepts:
> > ++ This test exercises the getcpuclockid methods.
> > ++ For pthread_getcpuclockid it gets the clockid_t for the current
> thread.
> > diff --git
> a/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.scn
> b/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.scn
> > index 0000000000..937a908fd5
> > --- /dev/null
> > +++ b/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.scn
> > @@ -0,0 +1,4 @@
> > +*** BEGIN OF TEST PSXGETCLOCKID 1 ***
> > +*** END OF TEST PSXGETCPUCLOCKID 1 ***
> Is this the output you get from running the test?
> yes, if the test runs successfully.
And got the same output on my terminal.
pthread_getcpuclockid() implemented in the patch
patch: https://lists.rtems.org/pipermail/devel/2020-March/058176.html
> > 2.17.1
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200408/932543e6/attachment-0001.html>
