BSP bset Build Failures (atsamv and pc)
Joel Sherrill
joel at rtems.org
Tue Apr 7 13:24:53 UTC 2020
Hi
It is hard to keep up so here's a summary post of build failures for the
BSP bsets. For those keeping track, it took 7.5 hours of build time on
a fast machine, just to learn that the atsamv and pc BSP bsets
fail to build but the others do.
RSB is at this commit:
commit 8223d3b7c02e48d2bec19c4c4c778525c611703f
Author: Chris Johns <chrisj at rtems.org>
Date: Mon Apr 6 17:05:37 2020 +1000
rtems/libbsd: Update to origin/5-freebsd12 HEAD.
atsamv ===========================================
1846/1914] Linking build/arm-rtems5-atsamv-default/epoch01.exe
/home/joel/rtems-work/rtems-source-builder/rtems/build/tmp/sb-1001-staging/bin/../lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld:linkcmds.base:326
cannot move location counter backwards (from 000000002047ab60 to
000000002045f000)
collect2: error: ld returned 1 exit status
cannot move location counter backwards (from 000000002053f9a0 to
000000002045f000)
000000002045f000)
Waf: Leaving directory
`/home/joel/rtems-work/rtems-source-builder/rtems/build/rtems-libbsd-v816a2f912f414f39467a6be901a96159f806c01d-x86_64-linux-gnu-1/rtems-libbsd-816a2f912f414f39467a6be901a96159f806c01d/build/arm-rtems5-atsamv-default'
Build failed
-> task in 'commands01.exe' failed with exit status 1 (run with -v to
display more information)
-> task in 'dhcpcd01.exe' failed with exit status 1 (run with -v to
-> task in 'dhcpcd02.exe' failed with exit status 1 (run with -v to
shell cmd failed: /bin/sh -ex
pc ===============================================
[ 51/1916] Compiling freebsd/sbin/sysctl/sysctl.c
../../freebsd/sbin/sysctl/sysctl.c:72:10: fatal error: machine/pc/bios.h:
No such file or directory
#include <machine/pc/bios.h>
compilation terminated.
`/home/joel/rtems-work/rtems-source-builder/rtems/build/rtems-libbsd-v816a2f912f414f39467a6be901a96159f806c01d-x86_64-linux-gnu-1/rtems-libbsd-816a2f912f414f39467a6be901a96159f806c01d/build/i386-rtems5-pc686-default'
Build failed
-> task in 'objs02' failed with exit status 1 (run with -v to display more
information)
/home/joel/rtems-work/rtems-source-builder/rtems/build/rtems-libbsd-v816a2f912f414f39467a6be901a96159f806c01d-x86_64-linux-gnu-1/do-build
error: building
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200407/7a700d1f/attachment.html>
