Use weak functions in the RTEMS core?
Sebastian Huber
Wed Apr 8 08:41:21 UTC 2020
On 08/04/2020 10:16, Sebastian Huber wrote:
> Hello,
> weak functions are already used in several places in RTEMS, but not in
> RTEMS core components. In <rtems/score/basedefs.h> we have currently
> only a RTEMS_WEAK_ALIAS() macro:
> testsuites/sptests/spmisc01/init.c:int weak_alias_func(void)
> RTEMS_WEAK_ALIAS(noinline_func);
> cpukit/libfs/src/defaults/default_mmap.c:) RTEMS_WEAK_ALIAS(
> rtems_filesystem_default_mmap );
> cpukit/libfs/src/defaults/default_poll.c:) RTEMS_WEAK_ALIAS(
> rtems_filesystem_default_poll );
> cpukit/libfs/src/defaults/default_kqfilter.c:) RTEMS_WEAK_ALIAS(
> rtems_filesystem_default_kqfilter );
> cpukit/include/rtems/score/basedefs.h: #define RTEMS_WEAK_ALIAS(
> _target ) __attribute__((__weak__, __alias__(#_target)))
> _target )
> It was introduced to allow libbsd to override implementations.
> I would like to use weak functions in two places. Firstly, the thread
> creation which has a dependency on thread deletion. Secondly, the C
> Program Heap allocation which has a dependency on deallocation (free).
> These dependencies could be satisfied by weak default implementations
> which do nothing. In case the application actually deletes threads or
> deallocates memory, then the dependencies can be satisfy by a strong
> implementation which actually performs the necessary work.
> An alternative to weak functions would be to use a global function
> pointer which is initialized to the default implementation (or NULL).
> In case the application actually deletes threads or deallocates
> memory, then a system initialization handler could set the function
> pointer to the proper implementations.
> What do you think about adding this to basedefs.h?
> * @brief Instructs the compiler to define a weak function.
> * Use this attribute for function definitions. Do not use it for
> function
> * declarations.
> #if defined(__GNUC__)
> #define RTEMS_WEAK __attribute__((__weak__))
> #else
> #define RTEMS_WEAK
> #endif
The benefit of using weak functions is that
* the linker can garbage collect the weak functions if a strong
implementation is provided and
* there is no global function pointer which must be changed and which
can be overwritten.
