Use weak functions in the RTEMS core?
Wed Apr 8 12:11:20 UTC 2020
On 08/04/2020 14:06, Andrew Butterfield wrote:
>  from my perspective as part of the qualification effort I suspect
> that weak functions are easier to reason about and verify than global
> pointers? Is my suspicion reasonable - I am more familiar with
> pointers (global or otherwise) than I am with how weak functions are
> implemented.
The problem with weak functions is that they need support from the
object format and linkers. I guess nowadays this is not really an issue
since every architecture relevant to RTEMS uses ELF.
