[PATCH 0/2] [rtems-tools] Allow telnet tty devices for run.cfg
Jan Sommer jan.sommer at dlr.de
Wed Apr 8 14:51:36 UTC 2020
Here are the changes I did for our local setup.
The first patch enableds telnet tty devices for run.cfg setups
The second add a run configuration for the pc BSP
Jan Sommer (2):
  tester: Allow telnet tty devices for run.cfg
  tester: Add configuration pc-run.ini
 tester/rtems/testing/bsps/pc-run.ini | 41 ++++++++++++++++++++++++++++++++++++
 tester/rtems/testing/run.cfg         |  4 +++-
 2 files changed, 44 insertions(+), 1 deletion(-)
 create mode 100644 tester/rtems/testing/bsps/pc-run.ini
2.12.3
