[PATCH 2/2] tester: Add configuration pc-run.ini
Jan Sommer
jan.sommer at dlr.de
Wed Apr 8 14:51:38 UTC 2020
tester/rtems/testing/bsps/pc-run.ini | 41 ++++++++++++++++++++++++++++++++++++
1 file changed, 41 insertions(+)
create mode 100644 tester/rtems/testing/bsps/pc-run.ini
diff --git a/tester/rtems/testing/bsps/pc-run.ini b/tester/rtems/testing/bsps/pc-run.ini
new file mode 100644
index 0000000..34ec2a4
--- /dev/null
+++ b/tester/rtems/testing/bsps/pc-run.ini
@@ -0,0 +1,41 @@
+# RTEMS Tools Project (http://www.rtems.org/)
+# Copyright 2010-2017 Chris Johns (chrisj at rtems.org)
+# All rights reserved.
+# This file is part of the RTEMS Tools package in 'rtems-tools'.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions are met:
+# 1. Redistributions of source code must retain the above copyright notice,
+# this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright notice,
+# this list of conditions and the following disclaimer in the documentation
+# and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
+# The pc686 hardware is started via a custom command. The console
+# is connected to a telnet tty device.
+[pc-run]
+bsp = pc686
+arch = i386
+tester = %{_rtscripts}/run.cfg
+jobs = 1
+test_restarts = 3
+requires = target_on_command, target_off_command, target_reset_command, bsp_tty_dev, bsp_run_cmd
2.12.3
