[PATCH 0/1] user/rsb/configuration.rst: Complete review on the text
clrrm at isep.ipp.pt
Wed Apr 8 16:55:33 UTC 2020
This patch proposes several fixes in the rsb/configuration.rst file.
The document was reviewed from top to bottom with the following
modifications being proposed:
- moved the paragraph describing the %source directive closer to where
the directive is introduced in the text, for readability purposes;
- corrected several typos;
- added two cross-references _bsets and _new-configs;
- restructured several sentences.
There are still some changes to be made concerning the DTC example as
the ones described in the following ticket (submitted as suggested by
Gedare Bloom):
- https://devel.rtems.org/ticket/3945
Cláudio Maia (1):
user/rsb/configuration.rst | 424 +++++++++++++++++++------------------
1 file changed, 215 insertions(+), 209 deletions(-)
2.17.1
