[PATCH 1/1] user/rsb/configuration.rst: Complete review on the text
clrrm at isep.ipp.pt
Wed Apr 8 16:55:34 UTC 2020
user/rsb/configuration.rst | 424 +++++++++++++++++++------------------
1 file changed, 215 insertions(+), 209 deletions(-)
diff --git a/user/rsb/configuration.rst b/user/rsb/configuration.rst
index 4b21dee..561ae60 100644
--- a/user/rsb/configuration.rst
+++ b/user/rsb/configuration.rst
@@ -8,23 +8,25 @@
Configuration
-The RTEMS Source Builder has two types of configuration data:
+The RTEMS Source Builder (RSB) has two types of configuration data:
-- Build Sets
+- Build Sets (see :ref:`bsets` for more info)
- Package Build Configurations
-By default these files can be located in two separate directories and
-searched. The first directory is ``config`` in your current working directory
-(``_topdir``) and the second is ``config`` located in the base directory of the
-RTEMS Source Builder command you run (``_sbdir``). The RTEMS directory
-``rtems``` located at the top of the RTEMS Source Builder source code is an
-example of a specific build configuration directory. You can create custom or
-private build configurations and if you run the RTEMS Source Builder command
-from that directory your configurations will be used.
+By default this type of files can be located and searched in two separate
+directories. The first directory is the ``config`` directory existing inside
+your current working directory (``_topdir``) and the second is the ``config``
+directory located inside the base directory of the RTEMS Source Builder command
+you run (``_sbdir``).
-The configuration search path is a macro variable and is reference as
-``%{_configdir}``. It's default is defined as:
+The ``rtems`` directory located at the top of the RTEMS Source Builder source
+code is an example of a specific build configuration directory. You can create
+custom or private build configurations and if you run the RTEMS Source Builder
+command from that directory your configurations will be used.
+The configuration search path is a macro variable and is referenced as
+``%{_configdir}``. Its default is defined as:
.. code-block:: spec
@@ -39,8 +41,8 @@ The configuration search path is a macro variable and is reference as
constraint and the definition.
Build set files have the file extension ``.bset`` and the package build
-configuration files have the file extension of ``.cfg``. The ``sb-set-builder``
-command will search for *build sets* and the ``sb-builder`` commands works with
+configuration files have the file extension ``.cfg``. The ``sb-set-builder``
+command will search for *build sets* and the ``sb-builder`` command works with
package build configuration files.
Both types of configuration files use the ``#`` character as a comment
@@ -50,13 +52,13 @@ block comment.
Source and Patches
-The RTEMS Source Builder provides a flexible way to manage source. Source and
-patches are declare in configurations file using the ``source`` and ``patch``
-directives. These are a single line containing a Universal Resource Location or
-URL and can contain macros and shell expansions. The :ref:`prep` section
-details the *source* and *patch* directives
+The RTEMS Source Builder provides a flexible way to manage the files source.
+Source and patches are declared in configuration files using the ``source`` and
+``patch`` directives. These are defined in a single line containing a Uniform
+Resource Locator (URL) and can contain macros and shell expansions. The
+:ref:`prep` section details the ``source`` and ``patch`` directives.
-The URL can reference remote and local source and patch resources. The
+The URL can reference remote and local sources and patch resources. The
following schemes are provided:
``http``:
@@ -75,21 +77,22 @@ following schemes are provided:
Remote access to a patch management repository.
``file``:
- Local access to an existing source directory.
+ Local access to an existing source directory.
HTTP, HTTPS, and FTP
-Remote access to TAR or ZIP files is provided using HTTP, HTTPS and FTP
+Remote access to TAR or ZIP files is provided using HTTP, HTTPS or FTP
protocols. The full URL provided is used to access the remote file including
any query components. The URL is parsed to extract the file component and the
-local source directory is checked for that file. If the file is located locally
-the remote file is not downloaded. Currently no other checks are made. If a
-download fails you need to manually remove the file from the source directory
+local source directory is checked for that file. If the file exists locally
+then the remote file is not downloaded. Currently, no other checks are made. If
+a download fails you need to manually remove the file from the source directory
and start the build process again.
The URL can contain macros. These are expanded before issuing the request to
-download the file. The standard GNU GCC compiler source URL is:
+download the file. As an example of the ``source`` directive, the standard GNU
+GCC compiler source URL is defined as follows:
@@ -97,11 +100,28 @@ download the file. The standard GNU GCC compiler source URL is:
.. topic:: Items:
- 1. The ``%source`` command's ``set`` command sets the source. The
- first is set and following sets are ignored.
+ 1. The ``%source`` command's ``set`` command sets the source. The first is
+ set and following sets are ignored.
2. The source package is part of the ``gcc`` group.
+The ``%source`` directive typically supports a single source file tar or zip
+file. The ``set`` command is used to set the URL for a specific source group.
+The first set command encountered is registered and any further set commands
+are ignored. This allows you to define a base standard source location and
+override it in build and architecture specific files. You can also add extra
+source files to a group. This is typically done when a collection of source
+is broken down into a number of smaller files and you require the full package.
+If the source URL references a GitHub API server https://api.github.com/, a
+tarball of the specified version is downloaded. For example, the URL for the
+STLINK project on GitHub and version is:
+.. code-block:: spec
+ %define stlink_version 3494c11
+ %source set stlink https://api.github.com/repos/texane/stlink/texane-stlink-%{stlink_version}.tar.gz
The type of compression is automatically detected from the file extension. The
supported compression formats are:
@@ -119,33 +139,14 @@ supported compression formats are:
The output of the decompression tool is fed to the standard ``tar`` utility if
not a ZIP file and unpacked into the build directory. ZIP files are unpacked by
-the decompression tool and all other files must be in the tar file format.
-The ``%source`` directive typically supports a single source file tar or zip
-file. The ``set`` command is used to set the URL for a specific source
-group. The first set command encountered is registered and any further set
-commands are ignored. This allows you to define a base standard source location
-and override it in build and architecture specific files. You can also add
-extra source files to a group. This is typically done when a collection of
-source is broken down in a number of smaller files and you require the full
-package. The source's ``setup`` command must reside in the ``%prep:`` section
-and it unpacks the source code ready to be built.
-If the source URL references the GitHub API server https://api.github.com/ a
-tarball of the specified version is download. For example the URL for the
-STLINK project on GitHub and version is:
-.. code-block:: spec
- %define stlink_version 3494c11
- %source set stlink https://api.github.com/repos/texane/stlink/texane-stlink-%{stlink_version}.tar.gz
+the decompression tool. All other files must be in the tar file format.
GIT
A GIT repository can be cloned and used as source. The GIT repository resides
in the 'source' directory under the ``git`` directory. You can edit, update and
-use the repository as you normally do and the results will used to build the
+use the repository as you normally do and the results will be used to build the
tools. This allows you to prepare and test patches in the build environment the
tools are built in. The GIT URL only supports the GIT protocol. You can control
the repository via the URL by appending options and arguments to the GIT
@@ -188,7 +189,7 @@ CVS
A CVS repository can be checked out. CVS is more complex than GIT to handle
-because of the modules support. This can effect the paths the source ends up
+because of the modules support. This can affect the paths the source ends up
in. The CVS URL only supports the CVS protocol. You can control the repository
via the URL by appending options and arguments to the CVS path. The options are
delimited by ``?`` and option arguments are delimited from the options with
@@ -215,34 +216,35 @@ The following is an example of checking out from a CVS repository:
Macros and Defaults
-The RTEMS Source Builder uses tables of *macros* read in when the tool
-runs. The initial global set of macros is called the *defaults*. These values
-are read from a file called ``defaults.mc`` and modified to suite your
-host. This host specific adaption lets the Source Builder handle differences in
-the build hosts.
+The RTEMS Source Builder uses tables of *macros* read in when the tool runs. The
+initial global set of macros is called the *defaults*. These values are read
+from a file called ``defaults.mc`` and modified to suite your host. This host
+specific adaption lets the Source Builder handle differences in the build hosts.
-Build set and configuration files can define new values updating and extending
-the global macro table. For example builds are given a release number. This is
+Build set and configuration files can define new values, updating and extending
+the global macro table. For example, builds are given a release number. This is
typically a single number at the end of the package name. For example:
%define release 1
-Once defined if can be accessed in a build set or package configuration file
+Once defined it can be accessed in a build set or package configuration file
with:
%{release}
-The ``sb-defaults`` command lists the defaults for your host. I will not include
-the output of this command because of its size:
+The ``sb-defaults`` command lists the defaults for your host.
.. code-block:: none
$ ../source-builder/sb-defaults
+Due to the amount of output produced by this command, its output is omitted
+from this documentation page.
A nested build set is given a separate copy of the global macro maps. Changes
in one change set are not seen in other build sets. That same happens with
configuration files unless inline includes are used. Inline includes are seen
@@ -280,7 +282,7 @@ where ``Name`` is a case insensitive macro name, the ``Type`` field is:
the ``Attribute`` field is:
``none``:
- Nothing, ignore
+ Nothing, ignore.
``required``:
The host check must find the executable or path.
@@ -298,8 +300,10 @@ the ``Attribute`` field is:
map's macro is not visible but still exists.
and the ``String`` field is a single or tripled multiline quoted string. The
-'String' can contain references to other macros. Macro that loop are not
-currently detected and will cause the tool to lock up.
+'String' can contain references to other macros.
+**IMPORTANT: Macros that loop are not currently detected and will cause the
+tool to lock up**.
Maps are declared anywhere in the map using the map directive:
@@ -316,18 +320,18 @@ Maps are declared anywhere in the map using the map directive:
1. The map is set to ``my-special-map``.
-Any macro definitions following a map declaration are placed in that map and the
-default map is ``global`` when loading a file. Maps are selected in
+Any macro definitions following a map declaration are placed in that map and
+the default map is ``global`` when loading a file. Maps are selected in
configuration files by using the ``%select`` directive:
%select my-special-map
-Selecting a map means all requests for a macro first check the selected map and
-if present return that value else the ``global`` map is used. Any new macros or
-changes update only the ``global`` map. This may change in future releases so
-please make sure you use the ``override`` attribute.
+Selecting a map means all requests for a macro first check the selected map,
+and if present, the requested value is returned, otherwise the ``global`` map
+is used. Any new macros or changes only update the ``global`` map. This may
+change in future releases so please make sure you use the ``override`` attribute.
The macro files specified on the command line are looked for in the
``_configdir`` paths. See the definition of ``_configdir`` in
@@ -336,7 +340,7 @@ The macro files specified on the command line are looked for in the
Macro map files can include other macro map files using the ``%include``
directive. The macro map to build *binutils*, *gcc*, *newlib*, *gdb* and
-RTEMS from version control heads is:
+RTEMS from version control head is:
@@ -350,7 +354,8 @@ RTEMS from version control heads is:
.. topic:: Items:
- 1. The file is ``config/snapshots/binutils-gcc-newlib-gdb-head.mc``.
+ 1. The code above can be found in the file
+ ``config/snapshots/binutils-gcc-newlib-gdb-head.mc``.
The macro map defaults to ``global`` at the start of each included file and the
map setting of the macro file including the other macro files does not change.
@@ -359,12 +364,11 @@ Personal Macros
When the tools start to run they will load personal macros. Personal macros are
-in the standard format for macros in a file. There are two places personal
-macros can be configured. The first is the environment variable
-``RSB_MACROS``. If present the macros from the file the environment variable
-points to are loaded. The second is a file called ``.rsb_macros`` in your home
-directory. You need to have the environment variable ``HOME`` defined for this
-work.
+in the standard format for macros in a file. There are two places where personal
+macros can be configured. The first is the environment variable ``RSB_MACROS``.
+If present, the macros from the file the environment variable points to are
+loaded. The second is a file called ``.rsb_macros`` in your home directory. You
+need to have the environment variable ``HOME`` defined for this to work.
Configuration Reports
@@ -384,8 +388,8 @@ Report Mailing
Configuration reports from a build can be mailed to a specific email address
-for logging and monitoring. Mailing requires a number of parameters to
-function. These are:
+for logging and monitoring purposes. Mailing requires a number of parameters to
+function properly. These are:
- To mail address
@@ -410,10 +414,10 @@ The ``from`` mail address is taken from:
- Command line
-If you have configured an email and name in git it will be used used. If you do
-not a check is made for a ``.mailrc`` file. The environment variable ``MAILRC``
-is used if present else your home directory is check. If found the file is
-scanned for the ``from`` setting:
+If you have configured an email and name in git these will be used. Otherwise,
+a check is made for a ``.mailrc`` file. The environment variable ``MAILRC``
+is used if present, otherwise the home directory is checked. If the file is
+found, then it is scanned for the ``from`` setting:
.. code-block:: shell
@@ -426,10 +430,12 @@ The SMTP host is taken from the macro ``%{_mail_smtp_host}`` and the
default is ``localhost``. You can override the default with a personal
or user macro file or via the command line option ``--smtp-host``.
+.. _bsets:
Build Set Files
-Build set files lets you list the packages in the build set you are defining
+Build set files let you list the packages in the build set you are defining
and have a file extension of ``.bset``. Build sets can define macro variables,
inline include other files and reference other build set or package
@@ -459,7 +465,7 @@ on a single line:
tools/rtems-binutils-2.22-1
The ``_configdir`` path is scanned for ``tools/rtems-binutils-2.22-1.bset`` or
-``tools/rtems-binutils-2.22-1.cfg``. Build set files take precedent over
+``tools/rtems-binutils-2.22-1.cfg``. Build set files take precedence over
package configuration files. If ``tools/rtems-binutils-2.22-1`` is a build set
a new instance of the build set processor is created and if the file is a
package configuration the package is built with the package builder. This all
@@ -468,7 +474,7 @@ happens once the build set file has finished being scanned.
Configuration Control
-The RTEMS Souce Builder is designed to fit within most verification and
+The RTEMS Source Builder is designed to fit within most verification and
validation processes. All of the RTEMS Source Builder is source code. The
Python code is source and comes with a commercial friendly license. All
configuration data is text and can be read or parsed with standard text based
@@ -478,9 +484,9 @@ File naming provides configuration management. A specific version of a package
is captured in a specific set of configuration files. The top level
configuration file referenced in a *build set* or passed to the ``sb-builder``
command relates to a specific configuration of the package being built. For
-example the RTEMS configuration file ``rtems-gcc-4.7.2-newlib-2.0.0-1.cfg``
+example, the RTEMS configuration file ``rtems-gcc-4.7.2-newlib-2.0.0-1.cfg``
creates an RTEMS GCC and Newlib package where the GCC version is 4.7.2, the
-Newlib version is 2.0.0, plus any RTEMS specific patches that related to this
+Newlib version is 2.0.0, plus any RTEMS specific patches that relate to this
version. The configuration defines the version numbers of the various parts
that make up this package:
@@ -501,7 +507,7 @@ The package build options, if there are any are also defined:
%define with_iconv 1
The generic configuration may provide defaults in case options are not
-specified. The patches this specific version of the package requires can be
+specified. The patches required by this specific version of the package can be
included:
@@ -519,9 +525,9 @@ Newlib. It is not specific to RTEMS. A bare no operating system tool set can be
built with this file.
The ``-1`` part of the file names is a revision. The GCC 4.7 script maybe
-revised to fix a problem and if this fix effects an existing script the file is
+revised to fix a problem and if this fix affects an existing script the file is
copied and given a ``-2`` revision number. Any dependent scripts referencing
-the earlier revision number will not be effected by the change. This locks down
+the earlier revision number will not be affected by the change. This locks down
a specific configuration over time.
Personal Configurations
@@ -533,7 +539,7 @@ source. There is also the ``bare`` set of configurations. You can create your
own configurations away from the RSB source tree yet use all that the RSB
provides.
-To create a private configuration change to a suitable directory:
+To create a private configuration change to a suitable directory, for instance:
@@ -543,8 +549,10 @@ To create a private configuration change to a suitable directory:
$ mkdir config
and create a ``config`` directory. Here you can add a new configuration or
-build set file. The section 'Adding New Configurations' details how to add a
-new confguration.
+build set file. The section :ref:`new-configs` details how to add a
+new configuration.
+.. _new-configs:
New Configurations
@@ -564,9 +572,9 @@ Layering by Including
Configurations can be layered using the ``%include`` directive. The user
invokes the outer layers which include inner layers until all the required
-configuration is present and the package can be built. The outer layers can
-provide high level details such as the version and the release and the inner
-layers provide generic configuration details that do not change from one
+configurations are present and the package can be built. The outer layers can
+provide high level details such as the version and the release, and the inner
+layers can provide generic configuration details that do not change from one
release to another. Macro variables are used to provide the specific
configuration details.
@@ -575,15 +583,15 @@ Configuration File Numbering
Configuration files have a number at the end. This is a release number for that
configuration and it gives us the ability to track a specific configuration for
-a specific version. For example lets say the developers of the DTC package
+a specific version. For example, let us assume the developers of the DTC package
change the build system from a single makefile to autoconf and automake between
version 1.3.0 and version 1.4.0. The configuration file used to build the
-package would change have to change. If we did not number the configuration
-files the ability to build 1.1.0, 1.2.0 or 1.3.0 would be lost if we update a
-common configuration file to build an autoconf and automake version. For
-version 1.2.0 the same build script can be used so we can share the same
-configuration file between version 1.1.0 and version 1.2.0. An update to any
-previous release lets us still build the package.
+package would have to change. If we did not number the configuration files the
+ability to build 1.1.0, 1.2.0 or 1.3.0 would be lost if we update a common
+configuration file to build an autoconf and automake version. For version 1.2.0
+the same build script can be used so we can share the same configuration file
+between version 1.1.0 and version 1.2.0. An update to any previous release lets
+us still build the package.
Common Configuration Scripts
@@ -592,9 +600,9 @@ Common configuration scripts that are independent of version, platform and
architecture are useful to everyone. These live in the Source Builder's
configuration directory. Currently there are scripts to build binutils, expat,
DTC, GCC, GDB and libusb. These files contain the recipes to build these
-package without the specific details of the versions or patches being
-built. They expect to be wrapped by a configuration file that ties the package
-to a specific version and optionally specific patches.
+packages without the specific details of the versions or patches being built.
+They expect to be wrapped by a configuration file that ties the package to a
+specific version and optionally specific patches.
DTC Example
@@ -607,23 +615,23 @@ this is a configuration file. The first ``1`` says this is for the major
release 1 of the package and the last ``1`` is the build configuration version.
The file starts with some comments that detail the configuration. If there is
-anything unusual about the configuration it is a good idea to add something in
-the comments here. The comments are followed by a check for the release. In
-this case if a release is not provided a default of 1 is used:
+anything unusual about the configuration it is a good idea to add a comment.
+The comments are followed by a check for the release. In this case if a release
+is not provided a default of 1 is used:
# DTC 1.x.x Version 1.
- # This configuration file configure's, make's and install's DTC.
+ # This configuration file configures, makes and installs the DTC.
%if %{release} == %{nil}
%define release 1
%endif
-The next section defines some information about the package. It does not effect
+The next section defines some information about the package. It does not affect
the build and is used to annotate the reports. It is recommended this
information is kept updated and accurate:
@@ -638,7 +646,7 @@ information is kept updated and accurate:
The next section defines the source and any patches. In this case there is a
single source package and it can be downloaded using the HTTP protocol. The RSB
-knows this is GZip'ped tar file. If more than one package is needed, add
+knows this is a GZip'ped tar file. If more than one package is needed, add
them increasing the index. The ``gcc-4.8-1.cfg`` configuration contains
examples of more than one source package as well as conditionally including
source packages based on the outer configuration options:
@@ -650,7 +658,7 @@ source packages based on the outer configuration options:
%source set dtc http://www.jdl.com/software/dtc-v%{dtc_version}.tgz
-The remainder of the script is broken in to the various phases of a build. They
+The remainder of the script is broken into the various phases of a build. They
are:
. Preparation
@@ -660,17 +668,17 @@ are:
Preparation is the unpacking of the source, applying any patches as well as any
package specific set ups. This part of the script is a standard Unix shell
-script. Be careful with the use of ``%`` and ``$``. The RSB uses ``%`` while
-the shell scripts use ``$``.
-A standard pattern you will observe is the saving of the build's top
-directory. This is used instead of changing into a subdirectory and then
-changing to the parent when finished. Some hosts will change in a subdirectory
-that is a link however changing to the parent does not change back to the
-parent of the link rather it changes to the parent of the target of the link
-and that is something the RSB nor you can track easily. The RSB configuration
-script's are a collection of various subtle issues so please ask if you are
-unsure why something is being done a particular way.
+script. **Be careful with the use of ``%`` and ``$``. The RSB uses ``%`` while
+the shell scripts use ``$``.**
+A standard pattern you will observe is the saving of the build's top directory.
+This is used instead of changing into a subdirectory and then changing to the
+parent when finished. Some hosts will change in a subdirectory that is a link
+however changing to the parent does not change back to the parent of the link,
+rather it changes to the parent of the target of the link and that is something
+the RSB nor you can track easily. The RSB configuration scripts are a
+collection of various subtle issues so please ask if you are unsure why
+something is being done a particular way.
The preparation phase will often include source and patch setup commands. Outer
layers can set the source package and add patches as needed while being able to
@@ -694,12 +702,12 @@ The configuration file ``gcc-common-1.cfg`` is a complex example of source
preparation. It contains a number of source packages and patches and it
combines these into a single source tree for building. It uses links to map
source into the GCC source tree so GCC can be built using the *single source
-tree* method. It also shows how to fetch source code from version
-control. Newlib is taken directly from its CVS repository.
+tree* method. It also shows how to fetch source code from version control.
+Newlib is taken directly from its CVS repository.
Next is the building phase and for the DTC example this is simply a matter of
running ``make``. Note the use of the RSB macros for commands. In the case of
-``%{__make}`` it maps to the correct make for your host. In the case of BSD
+``%{__make}`` it maps to the correct make on your host. In the case of BSD
systems we need to use the BSD make and not the GNU make.
If your package requires a configuration stage you need to run this before the
@@ -718,33 +726,33 @@ make stage. Again the GCC common configuration file provides a detailed example:
cd ${build_top}
-You can invoke make with the macro ``%{?_smp_flags}`` as a command line
+You can invoke ``make`` with the macro ``%{?_smp_flags}`` as a command line
argument. This macro is controlled by the ``--jobs`` command line option and
the host CPU detection support in the RSB. If you are on a multicore host you
-can increase the build speed using this macro. It also lets you disabled
+can increase the build speed using this macro. It also lets you disable
building on multicores to aid debugging when testing.
Next is the install phase. This phase is a little more complex because you may
-be building a tar file and the end result of the build is never actually
-installed into the prefix on the build host and you may not even have
+be building a tar file and the end result of the build may never actually be
+installed into the prefix on the build host or you may not even have
permissions to perform a real install. Most packages install to the ``prefix``
-and the prefix is typically supplied via the command to the RSB or the
-package's default is used. The default can vary depending on the host's
-operating system. To install to a path that is not the prefix the ``DESTDIR``
-make variable is used. Most packages should honour the ``DISTDIR`` make
-variables and you can typically specify it on the command line to make when
-invoking the install target. This results in the package being installed to a
-location that is not the prefix but one you can control. The RSB provides a
-shell variable called ``SB_BUILD_ROOT`` you can use. In a build set where you
-are building a number of packages you can collect all the built packages in a
-single tree that is captured in the tar file.
+which is typically supplied via the command to the RSB, otherwise the package's
+default is used. The default can vary depending on the host's operating system.
+To install to a path that is not the prefix, the ``DESTDIR`` make variable is
+used. Most packages should honour the ``DISTDIR`` make variables and you can
+typically specify it on the command line to make when invoking the install
+target. This results in the package being installed to a location that is not
+the prefix but one you can control. The RSB provides a shell variable called
+``SB_BUILD_ROOT`` you can use. In a build set where you are building a number
+of packages you can collect all the built packages in a single tree that is
+captured in the tar file. The code below shows the use of these variables.
Also note the use of the macro ``%{__rmdir}``. The use of these macros allow
the RSB to vary specific commands based on the host. This can help on hosts
-like Windows where bugs can effect the standard commands such as ``rm``. There
-are many many macros to help you. You can find these listed in the
-``defaults.mc`` file and in the trace output. If you are new to creating and
-editing configurations learning these can take a little time:
+like Windows where bugs can affect standard commands such as ``rm``. There
+are many macros to help you. You can find these listed in the ``defaults.mc``
+file and in the trace output. If you are new to creating and editing
+configurations learning these can take time:
@@ -759,8 +767,8 @@ editing configurations learning these can take a little time:
cd ${build_top}
Finally there is an optional clean section. The RSB will run this section if
-``--no-clean`` has not been provided on the command line. The RSB does clean up
-for you.
+``--no-clean`` has not been provided on the command line. The RSB does the
+clean up for you.
Once we have the configuration files we can execute the build using the
``sb-builder`` command. The command will perform the build and create a tar file
@@ -780,10 +788,10 @@ in the ``tar`` directory:
If you want to have the package installed automatically you need to create a
build set. A build set can build one or more packages from their configurations
-at once to create a single package. For example the GNU tools is typically seen
-as binutils, GCC and GDB and a build set will build each of these packages and
-create a single build set tar file or install the tools on the host into the
-prefix path.
+at once to create a single package. For example, the GNU tools package is
+typically seen as binutils, GCC and GDB and a build set will build each of
+these packages and create a single build set tar file or install the tools on
+the host into the prefix path.
The DTC build set file is called ``dtc.bset`` and contains:
@@ -814,31 +822,29 @@ To build this you can use something similar to:
$ ls tar
dtc-1.2.0-x86_64-freebsd9.1-1.tar.bz2 x86_64-freebsd9.1-dtc-set.tar.bz2
-The build is for a FreeBSD host and the prefix is for user installed
-packages. In this example I cannot let the source builder perform the install
-because I never run the RSB with root privileges so a build set or bset tar
-file is created. This can then be installed using root privileges.
+The build is for a FreeBSD host and the prefix is for user installed packages.
+In this example, the source builder creates a build set or bset tar file which
+can then be installed using root privileges.
-The command also supplies the ``--trace`` option. The output in the log file
-will contain all the macros.
+The command also supplies the ``--trace`` option which outputs in the log file
+all the macros.
Debugging
-New configuration files require debugging. There are two types of
-debugging. The first is debugging RSB script bugs. The ``--dry-run`` option is
-used here. Suppling this option will result in most of the RSB processing to be
-performed and suitable output placed in the log file. This with the ``--trace``
-option should help you resolve any issues.
-The second type of bug to fix are related to the execution of one of
-phases. These are usually a mix of shell script bugs or package set up or
-configuration bugs. Here you can use any normal shell script type debug
-technique such as ``set +x`` to output the commands or ``echo``
-statements. Debugging package related issues may require you start a build with
-the RSB and supply ``--no-clean`` option and then locate the build directories
-and change directory into them and manually run commands until to figure what
-the package requires.
+New configuration files require debugging. There are two types of debugging.
+The first is debugging RSB script bugs. The ``--dry-run`` option is used here.
+Supplying this option will result in most of the RSB processing to be performed
+and suitable output placed in the log file. This option in conjunction with the
+``--trace`` option should help you resolve any issues.
+The second type of bugs to fix are related to the execution of one of phases.
+These are usually a mix of shell script bugs or package set up or configuration
+bugs. Here you can use any normal shell script type debug technique such as
+``set +x`` to output the commands or ``echo`` statements. Debugging package
+related issues may require you start a build with the RSB and supply
+``--no-clean`` option and then locate the build directories and change directory
+into them and manually run commands until to figure what the package requires.
Scripting
@@ -924,7 +930,7 @@ The script language is implemented in terms of macros. The built-in list is:
Test the architecture against the following string.
``%ifnarch``:
- Inverted test of the architecture
+ Inverted test of the architecture.
``%ifos``:
Test the host operating system.
@@ -932,7 +938,7 @@ The script language is implemented in terms of macros. The built-in list is:
``%else``:
Start the *else* conditional logic block.
-``%endfi``:
+``%endif``:
End the conditional logic block.
``%bconf_with``:
@@ -946,12 +952,12 @@ The script language is implemented in terms of macros. The built-in list is:
Expanding
-A macro can be ``%{string}`` or the equivalent of ``%string``. The following macro
-expansions supported are:
+A macro can be ``%{string}`` or the equivalent of ``%string``. The macro
+expansions supported are the following:
``%{string}``:
Expand the 'string' replacing the entire macro text with the text in the
- table for the entry 'string . For example if 'var' is 'foo' then ``${var}``
+ table for the entry 'string'. For example if 'var' is 'foo' then ``${var}``
would become ``foo``.
``%{expand: string}``:
@@ -962,12 +968,12 @@ expansions supported are:
``%{with string}``:
Expand the macro to ``1`` if the macro ``with_string`` is defined else expand
- to ``0``. Macros with the name ``with_string`` can be define with command
+ to ``0``. Macros with the name ``with_string`` can be defined with command
line arguments to the RTEMS Source Builder commands.
``%{defined string}``:
Expand the macro to ``1`` if a macro of name ``string`` is defined else
- expand to '0'.
+ expand to ``0``.
``%{?string: expression}``:
Expand the macro to ``expression`` if a macro of name ``string`` is defined
@@ -975,7 +981,7 @@ expansions supported are:
``%{!?string: expression}``:
Expand the macro to ``expression`` if a macro of name ``string`` is not
- defined. If the macro is define expand to ``%{nil}``.
+ defined. If the macro is defined expand to ``%{nil}``.
``%(expression)``:
Expand the macro to the result of running the ``expression`` in a host
@@ -1006,7 +1012,7 @@ mixed with some shell commands to correct any source issues:
3. The version of the source is the macro ``%{version}``.
-The source set up are declared with the source ``set`` and ``add`` commands. For
+The source set up is declared with the source ``set`` and ``add`` commands. For
example:
@@ -1058,7 +1064,7 @@ Patching also occurs during the preparation stage. Patches are handled in a
similar way to the source packages except you only ``add`` patches. Patches are
applied using the `setup` command. The `setup` command takes the default patch
option. You can provide options with each patch by adding them as arguments
-before the patch URL. Patches with no options uses the `setup` default.
+before the patch URL. Patches with no options use the `setup` default.
@@ -1086,10 +1092,10 @@ To apply these patches:
The ``%build`` macro starts a block that continues until the next block
macro. The build block is a series of shell commands that execute to build the
-package. It assumes all source code has been unpacked, patch and adjusted so
+package. It assumes all source code has been unpacked, patched and adjusted so
the build will succeed.
-The following is an example take from the GitHub STLink project. The STLink is
+The following is an example taken from the GitHub STLink project. The STLink is
a JTAG debugging device for the ST ARM family of processors:
@@ -1197,13 +1203,13 @@ Looking at the same example as in :ref:`build`:
The ``%clean`` macro starts a block that continues until the next block
macro. The clean block is a series of shell commands that execute to clean up
-after a package has been built and install. This macro is currenly not been
+after a package has been built and install. This macro is currently not been
used because the RTEMS Source Builder automatically cleans up.
%include
-The ``%include`` macro inline includes the specific file. The ``__confdir``
+The ``%include`` macro "inline includes" the specific file. The ``__confdir``
path is searched. Any relative path component of the include file is appended
to each part of the ``__configdir``. Adding an extension is optional as files
with ``.bset`` and ``.cfg`` are automatically searched for.
@@ -1214,7 +1220,7 @@ configuration file that contains the ``%include`` macro.
Including files allow a kind of configuration file reuse. The outer
configuration files provide specific information such as package version
-numbers and patches and then include a generic configuration script which
+numbers and patches, and then include a generic configuration script which
builds the package:
@@ -1234,7 +1240,7 @@ with Newlib configuration the name is typically::
The ``%summary`` is a brief description of the package. It is useful when
-reporting. This information is not capture in the package anywhere. For the GCC
+reporting. This information is not captured in the package anywhere. For the GCC
with Newlib configuration the summary is typically:
@@ -1245,7 +1251,7 @@ with Newlib configuration the summary is typically:
The ``%release`` is a packaging number that allows revisions of a package to
-happen where no package versions change. This value typically increases when
+happen when no package versions change. This value typically increases when
the configuration building the package changes:
@@ -1255,11 +1261,11 @@ the configuration building the package changes:
%version
-The ``%version`` macro sets the version the package. If the package is a single
-component it tracks that component's version number. For example in the
+The ``%version`` macro sets the version of the package. If the package is a
+single component it tracks that component's version number. For example in the
``libusb`` configuration the ``%version`` is the same as ``%libusb_version``,
-however in a GCC with Newlib configuration there is no single version
-number. In this case the GCC version is used:
+however in a GCC with Newlib configuration there is no single version number.
+In this case the GCC version is used:
@@ -1270,19 +1276,19 @@ number. In this case the GCC version is used:
The ``%buildarch`` macro is set to the architecture the package contains. This
is currently not used in the RTEMS Source Builder and may go away. This macro
-is more important in a real packaging system where the package could end up on
+is more important in a real packaging system where the package could end up in
the wrong architecture.
%source
-The ``%source`` macro has 3 commands that controls what it does. You can
-``set`` the source files, ``add`` source files to a source group, and ``setup``
-the source file group getting it ready to be used.
+The ``%source`` macro has 3 commands that control what it does. You can ``set``
+the source files, ``add`` source files to a source group, and ``setup`` the
+source file group getting it ready to be used.
Source files are source code files in tar or zip files that are unpacked,
copied or symbolically linked into the package's build tree. Building a package
-requires one or more dependent packages. These are typically the packages
+requires one or more dependent packages. These are typically the packages'
source code plus dependent libraries or modules. You can create any number of
these source groups and set each of them up with a separate source group for
each needed library or module. Each source group normally has a single tar, zip
@@ -1336,22 +1342,22 @@ Accepted options are:
``-T``:
The ``-T`` option is used to direct %setup to not perform the default
- unpacking of the source archive specified by the first ``Source:`` macro. It
+ unpacking of the source archive specified by the first ``source:`` macro. It
is used with the ``-a`` or ``-b`` options.
``-b <n>``:
The ``-b`` option is used to direct ``%setup`` to unpack the source archive
- specified on the nth ``Source:`` macro line before changing directory into
+ specified on the nth ``source:`` macro line before changing directory into
%patch
-The ``%patch`` macro has the same 3 command as the ``%source`` command however
+The ``%patch`` macro has the same 3 commands as the ``%source`` command however
the ``set`` commands is not really that useful with the ``%patch`` command. You
add patches with the ``add`` command and ``setup`` applies the patches. Patch
options can be added to each patch by placing them before the patch URL. If no
-patch option is provided the default options passed to the ``setup`` command
+patch option is provided, the default options passed to the ``setup`` command
are used. An option starts with a ``-``. The ``setup`` command must reside
inside the ``%prep`` section.
@@ -1371,7 +1377,7 @@ To add a patch:
1. The patch group is ``gcc``.
- 2. Option ``-p0`` is this specific to this patch.
+ 2. Option ``-p0`` is specific to this patch.
Placing ``%patch setup`` in the ``%prep`` section will apply the groups
patches::
@@ -1395,7 +1401,7 @@ generates a warning.
A file to be checksummed must be unique in the source and patch directories.
The basename of the file is used as the key for the hash.
-The hash algorthim can be ``md5``, ``sha1``, ``sha224``, ``sha256``,
+The hash algorithm can be ``md5``, ``sha1``, ``sha224``, ``sha256``,
``sha384``, and ``sha512`` and we typically use ``md5``.
To add a hash:
@@ -1408,15 +1414,15 @@ To add a hash:
1. The type of checksum.
- 2. The file to checksum. It can contain macros that are expanded for you.
+ 2. The file to checksum. It can contain macros that are expanded.
3. The MD5 hash for the Net-SNMP file ``net-snmp-5.7.2.1.tar.gz``.
Do not include a path with the file name. Only the basename is required. Files
-can be searched for from a number of places and having a path conponent would
+can be searched for from a number of places and having a path component would
create confusion. This does mean files with hashes must be unique.
-Downloading off repositories such as git and cvs cannot be checksummed. It is
+Downloading off repositories such as git and CVS cannot be checksummed. It is
assumed those protocols and tools manage the state of the files.
%echo
@@ -1561,7 +1567,7 @@ The ``%if`` macro starts a conditional logic block that can optionally have a
- The left hand side is numerically greater than the right hand side.
- The left hand side is numerically greater than or equal to the
right hand side.
@@ -1608,7 +1614,7 @@ packages.
The ``%else`` macro starts the conditional *else* block.
-%endfi
+%endif
The ``%endif`` macro ends a conditional logic block.
2.17.1
