[PATCH] rsb: Fix Spike build
Gedare Bloom
gedare at rtems.org
Wed Apr 8 16:56:44 UTC 2020
Is the dtc version in spike hardcoded? If so would you update it to use the
dtc redirect instead?
On Wed, Apr 8, 2020, 4:18 AM Hesham Almatary <hesham.almatary at cl.cam.ac.uk>
wrote:
> Joel and Christian,
> Thanks for your review.
> Spike bset was already using dtc-1.4.1. I submitted patches to bump
> dtc.bset itself. Are there any other patches I should apply?
> Cheers,
> Hesham
> On Wed, 8 Apr 2020 at 10:18, Christian Mauderer <oss at c-mauderer.de> wrote:
> > Hello Hesham and Joel,
> > On 07/04/2020 16:01, Joel Sherrill wrote:
> > > Please apply your Christian's and your patch.
> > I haven't created a patch for 1.4 yet. But it's quite straightforward.
> > So maybe just create one instead of applying mine.
> > Best regards
> > Christian
> > > Also bump the dtc base package version number.
> > > I thought we settled on 1.4.
> > > --joel
> > > On Tue, Apr 7, 2020 at 3:56 AM Hesham Almatary
> > > <Hesham.Almatary at cl.cam.ac.uk <mailto:Hesham.Almatary at cl.cam.ac.uk>>
> wrote:
> > > * There is no all$ target in Spike
> > > * There is no longer --with-fesvr flag since fesvr is
> source-inlined
> > > by default
> > > source-builder/config/spike-1-1.cfg | 5 ++---
> > > 1 file changed, 2 insertions(+), 3 deletions(-)
> > > diff --git a/source-builder/config/spike-1-1.cfg
> > > b/source-builder/config/spike-1-1.cfg
> > > index 760e1cc..e731348 100644
> > > --- a/source-builder/config/spike-1-1.cfg
> > > +++ b/source-builder/config/spike-1-1.cfg
> > > @@ -37,10 +37,9 @@ URL:
> > > https://github.com/riscv/riscv-isa-sim/
> > > cd ${source_dir_spike}
> > > ./configure \
> > > - --prefix=%{_prefix} \
> > > - --with-fesvr=%{_prefix}
> > > + --prefix=%{_prefix}
> > > - %{__make} %{?_smp_mflags} all$
> > > + %{__make} %{?_smp_mflags}
> > > cd ${build_top}
> > > 2.17.1
> > > _______________________________________________
> > > devel mailing list
> > > devel at rtems.org <mailto:devel at rtems.org>
> > > http://lists.rtems.org/mailman/listinfo/devel
> > > devel mailing list
> > > devel at rtems.org
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200408/3f6b0f91/attachment.html>
