[PATCH] rtems-tester: Add rv64imafdc_medany for QEMU
Wed Apr 8 17:04:04 UTC 2020
This looks alright. I doubt EB has a copyright in this, though.
On Wed, Apr 8, 2020, 4:04 AM Hesham Almatary <Hesham.Almatary at cl.cam.ac.uk>
wrote:
>  .../rtems/testing/bsps/rv64imafdc_medany.ini  | 36 +++++++++++++++++++
>  1 file changed, 36 insertions(+)
>  create mode 100644 tester/rtems/testing/bsps/rv64imafdc_medany.ini
> diff --git a/tester/rtems/testing/bsps/rv64imafdc_medany.ini
> b/tester/rtems/testing/bsps/rv64imafdc_medany.ini
> new file mode 100644
> index 0000000..30abd50
> --- /dev/null
> +++ b/tester/rtems/testing/bsps/rv64imafdc_medany.ini
> @@ -0,0 +1,36 @@
> +# RTEMS Tools Project (http://www.rtems.org/)
> +# Copyright 2020 Hesham Almatary
> +# Copyright 2018 embedded brains GmbH
> +# All rights reserved.
> +# This file is part of the RTEMS Tools package in 'rtems-tools'.
> +# Redistribution and use in source and binary forms, with or without
> +# modification, are permitted provided that the following conditions are
> met:
> +# 1. Redistributions of source code must retain the above copyright
> notice,
> +# this list of conditions and the following disclaimer.
> +# 2. Redistributions in binary form must reproduce the above copyright
> notice,
> +# this list of conditions and the following disclaimer in the
> documentation
> +# and/or other materials provided with the distribution.
> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS
> IS"
> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS
> BE
> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
> THE
> +# POSSIBILITY OF SUCH DAMAGE.
> +[rv64imafdc_medany]
> +bsp           = rv64imafdc_medany
> +arch          = riscv64
> +tester        = %{_rtscripts}/qemu.cfg
> +bsp_qemu_opts = -no-reboot -nographic %{qemu_opts_no_net} -machine virt
> -m 64M
> 2.17.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200408/294c2b79/attachment.html>
