[PATCH] rtems-tester: Add rv64imafdc_medany for QEMU
Hesham Almatary hesham.almatary at cl.cam.ac.uk
Wed Apr 8 17:51:31 UTC 2020
Hello Gedare,
I copied that file from rv64imafd which has that copyright header
On Wed, 8 Apr 2020 at 18:04, Gedare Bloom <gedare at rtems.org> wrote:
> This looks alright. I doubt EB has a copyright in this, though.
> On Wed, Apr 8, 2020, 4:04 AM Hesham Almatary <Hesham.Almatary at cl.cam.ac.uk> wrote:
>>  .../rtems/testing/bsps/rv64imafdc_medany.ini  | 36 +++++++++++++++++++
>>  1 file changed, 36 insertions(+)
>>  create mode 100644 tester/rtems/testing/bsps/rv64imafdc_medany.ini
>> diff --git a/tester/rtems/testing/bsps/rv64imafdc_medany.ini b/tester/rtems/testing/bsps/rv64imafdc_medany.ini
>> new file mode 100644
>> index 0000000..30abd50
>> --- /dev/null
>> +++ b/tester/rtems/testing/bsps/rv64imafdc_medany.ini
>> @@ -0,0 +1,36 @@
>> +# RTEMS Tools Project (http://www.rtems.org/)
>> +# Copyright 2020 Hesham Almatary
>> +# Copyright 2018 embedded brains GmbH
>> +# All rights reserved.
>> +# This file is part of the RTEMS Tools package in 'rtems-tools'.
>> +# Redistribution and use in source and binary forms, with or without
>> +# modification, are permitted provided that the following conditions are met:
>> +# 1. Redistributions of source code must retain the above copyright notice,
>> +# this list of conditions and the following disclaimer.
>> +# 2. Redistributions in binary form must reproduce the above copyright notice,
>> +# this list of conditions and the following disclaimer in the documentation
>> +# and/or other materials provided with the distribution.
>> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
>> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
>> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
>> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
>> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
>> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
>> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
>> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
>> +# POSSIBILITY OF SUCH DAMAGE.
>> +[rv64imafdc_medany]
>> +bsp           = rv64imafdc_medany
>> +arch          = riscv64
>> +tester        = %{_rtscripts}/qemu.cfg
>> +bsp_qemu_opts = -no-reboot -nographic %{qemu_opts_no_net} -machine virt -m 64M
>> 2.17.1
>> devel mailing list
>> devel at rtems.org
