[PATCH 0/2] [rtems-tools] Allow telnet tty devices for run.cfg
Gedare Bloom
gedare at rtems.org
Wed Apr 8 17:06:43 UTC 2020
These look alright to me, although I wonder if we need some bsp doc for
this setup?
On Wed, Apr 8, 2020, 9:23 AM Jan Sommer <jan.sommer at dlr.de> wrote:
> Here are the changes I did for our local setup.
> The first patch enableds telnet tty devices for run.cfg setups
> The second add a run configuration for the pc BSP
> Jan Sommer (2):
> tester: Allow telnet tty devices for run.cfg
> tester: Add configuration pc-run.ini
> tester/rtems/testing/bsps/pc-run.ini | 41
> tester/rtems/testing/run.cfg | 4 +++-
> 2 files changed, 44 insertions(+), 1 deletion(-)
> create mode 100644 tester/rtems/testing/bsps/pc-run.ini
> 2.12.3
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200408/0a718e5a/attachment.html>
