AW: [PATCH 0/2] [rtems-tools] Allow telnet tty devices for run.cfg
Jan.Sommer at dlr.de
Wed Apr 8 19:35:44 UTC 2020
Could you give me some direction where we would add the documentation and what is missing?
The pc-run.ini is basically a copy of the xilinx_zynq_zedboard.ini with just a different tester.
Or do you mean the change in the run.cfg?
Von: Gedare Bloom [mailto:gedare at rtems.org]
Gesendet: Mittwoch, 8. April 2020 19:07
An: Sommer, Jan
Cc: devel at rtems.org
Betreff: Re: [PATCH 0/2] [rtems-tools] Allow telnet tty devices for run.cfg
These look alright to me, although I wonder if we need some bsp doc for this setup?
On Wed, Apr 8, 2020, 9:23 AM Jan Sommer <jan.sommer at dlr.de<mailto:jan.sommer at dlr.de>> wrote:
Here are the changes I did for our local setup.
The first patch enableds telnet tty devices for run.cfg setups
The second add a run configuration for the pc BSP
Jan Sommer (2):
tester: Allow telnet tty devices for run.cfg
tester: Add configuration pc-run.ini
tester/rtems/testing/bsps/pc-run.ini | 41 ++++++++++++++++++++++++++++++++++++
tester/rtems/testing/run.cfg | 4 +++-
2 files changed, 44 insertions(+), 1 deletion(-)
create mode 100644 tester/rtems/testing/bsps/pc-run.ini
2.12.3
_____________________________________________
devel mailing list
devel at rtems.org<mailto:devel at rtems.org>
http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200408/a4188f0a/attachment.html>
