[PATCH 2/3] bsps/powerpc: Fix inline assembly
    Sebastian Huber
    Wed Apr  8 17:35:23 UTC 2020
GCC 10 no longer passes -many to the assembler.  This enables more
checks in the assembler.
 bsps/powerpc/include/libcpu/powerpc-utility.h      | 73 ++++++++++++++++++++++
 bsps/powerpc/qoriq/start/bspstart.c                |  5 +-
 bsps/powerpc/qoriq/start/mmu.c                     |  7 ++-
 .../powerpc/shared/exceptions/ppc_exc_initialize.c | 45 +++++++------
 bsps/powerpc/shared/mmu/e500-mmu.c                 | 31 +++++----
 5 files changed, 114 insertions(+), 47 deletions(-)
diff --git a/bsps/powerpc/include/libcpu/powerpc-utility.h b/bsps/powerpc/include/libcpu/powerpc-utility.h
index 60cfe85f60..2827430e13 100644
--- a/bsps/powerpc/include/libcpu/powerpc-utility.h
+++ b/bsps/powerpc/include/libcpu/powerpc-utility.h
@@ -860,6 +860,79 @@ static inline uint32_t ppc_fsl_system_version_mnrev(uint32_t svr)
   return (svr >> 0) & 0xf;
+static inline void ppc_msync(void)
+  __asm__ volatile (
+    ".machine push\n"
+    ".machine e500\n"
+    "msync\n"
+    ".machine pop"
+    : "memory"
+static inline void ppc_tlbre(void)
+    ".machine push\n"
+    ".machine e500\n"
+    "tlbre\n"
+    ".machine pop"
+    : "memory"
+static inline void ppc_tlbwe(void)
+    ".machine push\n"
+    ".machine e500\n"
+    "tlbwe\n"
+    ".machine pop"
+    : "memory"
+static inline void ppc_tlbsx(void *addr)
+    ".machine push\n"
+    ".machine e500\n"
+    "tlbsx 0, %0\n"
+    ".machine pop"
+    : "r" (addr)
+    : "memory"
+static inline void ppc_mtivpr(void *prefix)
+    ".machine push\n"
+    ".machine e500\n"
+    "mtivpr %0\n"
+    ".machine pop"
+    : "r" (prefix)
+#define ppc_mtivor(x, vec) __asm__ volatile ( \
+    ".machine push\n" \
+    ".machine e500\n" \
+    "mtivor" RTEMS_XSTRING(x) " %0\n" \
+    ".machine pop" \
+    : "r" (vec) \
 void ppc_code_copy(void *dest, const void *src, size_t n);
 /* FIXME: Do not use this function */
diff --git a/bsps/powerpc/qoriq/start/bspstart.c b/bsps/powerpc/qoriq/start/bspstart.c
index 3c75ecf020..5abd651a27 100644
--- a/bsps/powerpc/qoriq/start/bspstart.c
+++ b/bsps/powerpc/qoriq/start/bspstart.c
@@ -93,9 +93,6 @@ static void initialize_frequency_parameters(void)
   #endif
-#define MTIVPR(base) \
-  __asm__ volatile ("mtivpr %0" : : "r" (base))
 #ifdef __powerpc64__
 #define VECTOR_TABLE_ENTRY_SIZE 32
 #else
@@ -117,7 +114,7 @@ void qoriq_initialize_exceptions(void *interrupt_stack_begin)
   addr = (uintptr_t) bsp_exc_vector_base;
-  MTIVPR(addr);
+  ppc_mtivpr((void *) addr);
   MTIVOR(BOOKE_IVOR0,  addr);
   MTIVOR(BOOKE_IVOR1,  addr);
   MTIVOR(BOOKE_IVOR2,  addr);
diff --git a/bsps/powerpc/qoriq/start/mmu.c b/bsps/powerpc/qoriq/start/mmu.c
index b912613cc4..558c49618a 100644
--- a/bsps/powerpc/qoriq/start/mmu.c
+++ b/bsps/powerpc/qoriq/start/mmu.c
@@ -350,7 +350,7 @@ void qoriq_mmu_change_perm(uint32_t test, uint32_t set, uint32_t clear)
 		uint32_t mas1 = 0;
 		PPC_SET_SPECIAL_PURPOSE_REGISTER(FSL_EIS_MAS0, mas0);
-		asm volatile ("tlbre");
+		ppc_tlbre();
 		mas1 = PPC_SPECIAL_PURPOSE_REGISTER(FSL_EIS_MAS1);
 		if ((mas1 & FSL_EIS_MAS1_V) != 0) {
@@ -361,7 +361,10 @@ void qoriq_mmu_change_perm(uint32_t test, uint32_t set, uint32_t clear)
 				mas3 &= ~(clear & mask);
 				mas3 |= set & mask;
 				PPC_SET_SPECIAL_PURPOSE_REGISTER(FSL_EIS_MAS3, mas3);
-				asm volatile ("msync; isync; tlbwe; isync" : : : "memory");
+				ppc_msync();
+				ppc_synchronize_instructions();
+				ppc_tlbwe();
diff --git a/bsps/powerpc/shared/exceptions/ppc_exc_initialize.c b/bsps/powerpc/shared/exceptions/ppc_exc_initialize.c
index 215918ac44..46b72524ea 100644
--- a/bsps/powerpc/shared/exceptions/ppc_exc_initialize.c
+++ b/bsps/powerpc/shared/exceptions/ppc_exc_initialize.c
@@ -29,13 +29,10 @@
 uint32_t ppc_exc_cache_wb_check = 1;
-#define MTIVPR(prefix) __asm__ volatile ("mtivpr %0" : : "r" (prefix))
-#define MTIVOR(x, vec) __asm__ volatile ("mtivor"#x" %0" : : "r" (vec))
 static void ppc_exc_initialize_booke(void *vector_base)
   /* Interrupt vector prefix register */
-  MTIVPR((uintptr_t) vector_base);
+  ppc_mtivpr(vector_base);
   if (
     ppc_cpu_is_specific_e200(PPC_e200z0)
@@ -49,29 +46,29 @@ static void ppc_exc_initialize_booke(void *vector_base)
   /* Interupt vector offset registers */
-  MTIVOR(0,  ppc_exc_vector_address(ASM_BOOKE_CRIT_VECTOR, vector_base));
-  MTIVOR(1,  ppc_exc_vector_address(ASM_MACH_VECTOR, vector_base));
-  MTIVOR(2,  ppc_exc_vector_address(ASM_PROT_VECTOR, vector_base));
-  MTIVOR(3,  ppc_exc_vector_address(ASM_ISI_VECTOR, vector_base));
-  MTIVOR(4,  ppc_exc_vector_address(ASM_EXT_VECTOR, vector_base));
-  MTIVOR(5,  ppc_exc_vector_address(ASM_ALIGN_VECTOR, vector_base));
-  MTIVOR(6,  ppc_exc_vector_address(ASM_PROG_VECTOR, vector_base));
-  MTIVOR(7,  ppc_exc_vector_address(ASM_FLOAT_VECTOR, vector_base));
-  MTIVOR(8,  ppc_exc_vector_address(ASM_SYS_VECTOR, vector_base));
-  MTIVOR(9,  ppc_exc_vector_address(ASM_BOOKE_APU_VECTOR, vector_base));
-  MTIVOR(10, ppc_exc_vector_address(ASM_BOOKE_DEC_VECTOR, vector_base));
-  MTIVOR(11, ppc_exc_vector_address(ASM_BOOKE_FIT_VECTOR, vector_base));
-  MTIVOR(12, ppc_exc_vector_address(ASM_BOOKE_WDOG_VECTOR, vector_base));
-  MTIVOR(13, ppc_exc_vector_address(ASM_BOOKE_DTLBMISS_VECTOR, vector_base));
-  MTIVOR(14, ppc_exc_vector_address(ASM_BOOKE_ITLBMISS_VECTOR, vector_base));
-  MTIVOR(15, ppc_exc_vector_address(ASM_BOOKE_DEBUG_VECTOR, vector_base));
+  ppc_mtivor(0,  ppc_exc_vector_address(ASM_BOOKE_CRIT_VECTOR, vector_base));
+  ppc_mtivor(1,  ppc_exc_vector_address(ASM_MACH_VECTOR, vector_base));
+  ppc_mtivor(2,  ppc_exc_vector_address(ASM_PROT_VECTOR, vector_base));
+  ppc_mtivor(3,  ppc_exc_vector_address(ASM_ISI_VECTOR, vector_base));
+  ppc_mtivor(4,  ppc_exc_vector_address(ASM_EXT_VECTOR, vector_base));
+  ppc_mtivor(5,  ppc_exc_vector_address(ASM_ALIGN_VECTOR, vector_base));
+  ppc_mtivor(6,  ppc_exc_vector_address(ASM_PROG_VECTOR, vector_base));
+  ppc_mtivor(7,  ppc_exc_vector_address(ASM_FLOAT_VECTOR, vector_base));
+  ppc_mtivor(8,  ppc_exc_vector_address(ASM_SYS_VECTOR, vector_base));
+  ppc_mtivor(9,  ppc_exc_vector_address(ASM_BOOKE_APU_VECTOR, vector_base));
+  ppc_mtivor(10, ppc_exc_vector_address(ASM_BOOKE_DEC_VECTOR, vector_base));
+  ppc_mtivor(11, ppc_exc_vector_address(ASM_BOOKE_FIT_VECTOR, vector_base));
+  ppc_mtivor(12, ppc_exc_vector_address(ASM_BOOKE_WDOG_VECTOR, vector_base));
+  ppc_mtivor(13, ppc_exc_vector_address(ASM_BOOKE_DTLBMISS_VECTOR, vector_base));
+  ppc_mtivor(14, ppc_exc_vector_address(ASM_BOOKE_ITLBMISS_VECTOR, vector_base));
+  ppc_mtivor(15, ppc_exc_vector_address(ASM_BOOKE_DEBUG_VECTOR, vector_base));
   if (ppc_cpu_is_e200() || ppc_cpu_is_e500()) {
-    MTIVOR(32, ppc_exc_vector_address(ASM_E500_SPE_UNAVAILABLE_VECTOR, vector_base));
-    MTIVOR(33, ppc_exc_vector_address(ASM_E500_EMB_FP_DATA_VECTOR, vector_base));
-    MTIVOR(34, ppc_exc_vector_address(ASM_E500_EMB_FP_ROUND_VECTOR, vector_base));
+    ppc_mtivor(32, ppc_exc_vector_address(ASM_E500_SPE_UNAVAILABLE_VECTOR, vector_base));
+    ppc_mtivor(33, ppc_exc_vector_address(ASM_E500_EMB_FP_DATA_VECTOR, vector_base));
+    ppc_mtivor(34, ppc_exc_vector_address(ASM_E500_EMB_FP_ROUND_VECTOR, vector_base));
   if (ppc_cpu_is_specific_e200(PPC_e200z7) || ppc_cpu_is_e500()) {
-    MTIVOR(35, ppc_exc_vector_address(ASM_E500_PERFMON_VECTOR, vector_base));
+    ppc_mtivor(35, ppc_exc_vector_address(ASM_E500_PERFMON_VECTOR, vector_base));
diff --git a/bsps/powerpc/shared/mmu/e500-mmu.c b/bsps/powerpc/shared/mmu/e500-mmu.c
index 15fe88f91a..ee69172e46 100644
--- a/bsps/powerpc/shared/mmu/e500-mmu.c
+++ b/bsps/powerpc/shared/mmu/e500-mmu.c
@@ -75,6 +75,7 @@
 #include <libcpu/e500_mmu.h>
+#include <libcpu/powerpc-utility.h>
 #define TLBIVAX_TLBSEL  (1<<(63-60))
 #define TLBIVAX_INV_ALL  (1<<(63-61))
@@ -215,7 +216,7 @@ rtems_e500_prtlb(rtems_e500_tlb_idx key, int quiet, FILE *f)
   seltlb( key );
-  asm volatile("tlbre");
+  ppc_tlbre();
   /* not manipulating MAS0, skip reading it */
   mas1 = _read_MAS1();
@@ -433,13 +434,11 @@ rtems_interrupt_level lvl;
   _write_MAS3(mas3);
   _write_MAS4(mas4);
-  asm volatile(
-    "  sync\n"
-    "  isync\n"
-    "  tlbwe\n"
-    "  sync\n"
-    "  isync\n"
+  ppc_synchronize_data();
+  ppc_tlbwe();
   rtems_interrupt_enable(lvl);
@@ -536,7 +535,7 @@ rtems_interrupt_level lvl;
     _write_MAS6( FSL_EIS_MAS6_SPID0(pid) | (as ? FSL_EIS_MAS6_SAS : 0 ) );
-    asm volatile("tlbsx 0, %0"::"r"(ea));
+    ppc_tlbsx((void *)(uintptr_t) ea);
@@ -608,18 +607,16 @@ rtems_interrupt_level lvl;
   seltlb(key);
+  ppc_tlbre();
   /* read old entries */
   _write_MAS1( _read_MAS1() & ~FSL_EIS_MAS1_V );
-  asm volatile(
-    "  sync\n"
-    "  isync\n"
-    "  tlbwe\n"
-    "  sync\n"
-    "  isync\n"
+  ppc_tlbwe();
   /* update cache */
   if ( E500_SELTLB_1 & key )
2.16.4
