[PATCH 0/3] GCC 10 fixes for powerpc
Wed Apr 8 17:51:42 UTC 2020
Thanks they should be ok after the release. Hard to tell what might break
in subtle ways from asm changes
On Wed, Apr 8, 2020, 11:35 AM Sebastian Huber <
> The following patch set fixes some compile time problems with GCC 10 on
> powerpc.
> I am not sure if every change is correct, especially I am not sure about
> the
> tlbie change since I had problems to figure out what is going on.  This is
> probably something for RTEMS 6.
> Sebastian Huber (3):
>   bsp/qoriq: Fix tlbwe sequence
>   bsps/powerpc: Fix inline assembly
>   bsps/powerpc: Fix tlbie instruction usage
>  bsps/powerpc/gen5200/start/start.S                 |  2 +-
>  bsps/powerpc/gen83xx/start/cpuinit.c               |  2 +-
>  bsps/powerpc/include/libcpu/mmu.h                  |  2 +-
>  bsps/powerpc/include/libcpu/powerpc-utility.h      | 73
>  bsps/powerpc/motorola_powerpc/bootloader/head.S    |  2 +-
>  bsps/powerpc/motorola_powerpc/bootloader/mm.c      |  4 +-
>  bsps/powerpc/mvme5500/start/start.S                |  2 +-
>  bsps/powerpc/qoriq/start/bspstart.c                |  5 +-
>  bsps/powerpc/qoriq/start/mmu.c                     |  7 ++-
>  .../powerpc/shared/exceptions/ppc_exc_initialize.c | 45 +++++++------
>  bsps/powerpc/shared/mmu/e500-mmu.c                 | 31 +++++----
>  bsps/powerpc/shared/mmu/pte121.c                   | 11 ++--
>  bsps/powerpc/shared/start/start.S                  |  2 +-
>  13 files changed, 128 insertions(+), 60 deletions(-)
> 2.16.4
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200408/359f9443/attachment.html>
