AW: [PATCH 0/2] [rtems-tools] Allow telnet tty devices for run.cfg
Wed Apr 8 23:05:09 UTC 2020
On Wed, Apr 8, 2020 at 4:42 PM Chris Johns <chrisj at rtems.org> wrote:
> On 2020-04-09 05:35, Jan.Sommer at dlr.de wrote:
> > Could you give me some direction where we would add the documentation
> > and what is missing?
> > The pc-run.ini is basically a copy of the xilinx_zynq_zedboard.ini with
> > just a different tester.
> What you have done is create a new form of running a test on target
> hardware and this is really neat. The zedboard uses TFTP just like the
> pc.ini config.
> > Or do you mean the change in the run.cfg?
> The run.cfg was a general means to execute a command and the intention
> was simulation, i.e. qemu etc, so it would be great to document how you
> have used the various commands to glue the tester to your set up.
> Should a new section below Simulation called Execution be added or
> should Simulation be changed to Execution and Simulation is placed under
> Execution?
the latter. Execution is the general form, Simulation is an instantiation
> Chris
