AW: [PATCH 0/2] [rtems-tools] Allow telnet tty devices for run.cfg
Wed Apr 8 22:41:47 UTC 2020
On 2020-04-09 05:35, Jan.Sommer at dlr.de wrote:
> Could you give me some direction where we would add the documentation
> and what is missing?
> The pc-run.ini is basically a copy of the xilinx_zynq_zedboard.ini with
> just a different tester.
What you have done is create a new form of running a test on target
hardware and this is really neat. The zedboard uses TFTP just like the
pc.ini config.
> Or do you mean the change in the run.cfg?
The run.cfg was a general means to execute a command and the intention
was simulation, i.e. qemu etc, so it would be great to document how you
have used the various commands to glue the tester to your set up.
Should a new section below Simulation called Execution be added or
should Simulation be changed to Execution and Simulation is placed under
Execution?
