Use weak functions in the RTEMS core?
Chris Johns
chrisj at rtems.org
Thu Apr 9 01:32:03 UTC 2020
On 2020-04-09 03:43, Sebastian Huber wrote:
> On 08/04/2020 19:34, Jonathan Brandmeyer wrote:
>> Instead of treating weak references as a single level of indirection,
>> I think you have to treat them as a single overridable interface. In
>> a dynamically-linked application, we might try to perform an override
>> using the LD_PRELOAD feature. But in a statically-linked application
>> we have to do it differently. The overriding archive must be named in
>> full, and it must be named as an object to be linked instead of a
>> library to be searched. Furthermore, an interface can have only one
>> override that ends up in the linked application.
> Yes, you can only have one strong implementation, otherwise you get
> multiple definition errors.
I have only ever considered weak references as an overridable interface
within a user's application and not layered within RTEMS itself. I am
not sure about automatic indirection within an archive.
In the case of different heap allocators why not have confdefs.h select
the one we want and manage the indirection with a const table of pointers?
