Use weak functions in the RTEMS core?
Thu Apr 9 04:53:47 UTC 2020
On 09/04/2020 03:32, Chris Johns wrote:
> On 2020-04-09 03:43, Sebastian Huber wrote:
>> On 08/04/2020 19:34, Jonathan Brandmeyer wrote:
>>> Instead of treating weak references as a single level of
>>> indirection, I think you have to treat them as a single overridable
>>> interface.  In a dynamically-linked application, we might try to
>>> perform an override using the LD_PRELOAD feature. But in a
>>> statically-linked application we have to do it differently.  The
>>> overriding archive must be named in full, and it must be named as an
>>> object to be linked instead of a library to be searched.
>>> Furthermore, an interface can have only one override that ends up in
>>> the linked application.
>> Yes, you can only have one strong implementation, otherwise you get
>> multiple definition errors.
> I have only ever considered weak references as an overridable
> interface within a user's application and not layered within RTEMS
> itself. I am not sure about automatic indirection within an archive.
Yes, this is one use case. You could use also a normal function in a
separate file to get something similar.
> In the case of different heap allocators why not have confdefs.h
> select the one we want and manage the indirection with a const table
> of pointers?
Yes it can be done with new configuration options, however, this would
be my least favorite choice. I created an example how I would like to
use weak functions:
https://lists.rtems.org/pipermail/devel/2020-April/059196.html
