[PATCH v4 0/3] [5-freebsd-12] Fix compilation for i386
Jan Sommer jan.sommer at dlr.de
Thu Apr 9 13:56:53 UTC 2020
This is the  backport for the 5-freebsd-12 branch to make rtems-libbsd compile for i386 again:
- It also introduces path-mappings to waf_libbsd.py as introduced here:
https://lists.rtems.org/pipermail/devel/2020-February/057457.html
Changes compared to v3:
- iflib.c: Properly deactivate usage of ifc_cpus
- subr_gtaskqueue.c: Deactivate BSD_ASSERT for i386 (will open a
  discussion for that)
- Could successfully run network tests (e.g. dhcpcd0x.exe on hardware)
Changes compared to v2:
- callout.h: Change the callout_reset_on macro
- iflib.c: Do not use different callout* macro, but use the changed one
Happy Easter,
   Jan
Jan Sommer (3):
  i386: Add missing files from FreeBSD
  i386: Update build system
  i386: Port to RTEMS
 freebsd-org                                        |    2 +-
 freebsd/sbin/sysctl/sysctl.c                       |    8 +
 freebsd/sys/dev/pci/pci_pci.c                      |    2 +
 freebsd/sys/i386/include/machine/cpufunc.h         |    2 +
 freebsd/sys/kern/subr_gtaskqueue.c                 |    4 +
 freebsd/sys/net/iflib.c                            | 6771 ++++++++++++++++++++
 freebsd/sys/net/iflib_private.h                    |   76 +
 freebsd/sys/net/mp_ring.c                          |  554 ++
 freebsd/sys/net/mp_ring.h                          |   75 +
 freebsd/sys/sys/callout.h                          |    6 +
 freebsd/sys/x86/include/machine/intr_machdep.h     |  180 +
 .../sys/{i386 => x86}/include/machine/legacyvar.h  |   26 +-
 freebsd/sys/{i386/i386 => x86/x86}/legacy.c        |   77 +-
 libbsd.py                                          |   17 +-
 rtemsbsd/i386/include/machine/clock.h              |    2 +
 rtemsbsd/include/rtems/bsd/local/opt_acpi.h        |    0
 rtemsbsd/include/x86/legacyvar.h                   |    1 +
 rtemsbsd/include/x86/specialreg.h                  | 1074 ++++
 rtemsbsd/include/x86/x86_var.h                     |  156 +
 waf_libbsd.py                                      |   13 +-
 20 files changed, 9006 insertions(+), 40 deletions(-)
 create mode 100644 freebsd/sys/net/iflib.c
 create mode 100644 freebsd/sys/net/iflib_private.h
 create mode 100644 freebsd/sys/net/mp_ring.c
 create mode 100644 freebsd/sys/net/mp_ring.h
 create mode 100644 freebsd/sys/x86/include/machine/intr_machdep.h
 rename freebsd/sys/{i386 => x86}/include/machine/legacyvar.h (76%)
 rename freebsd/sys/{i386/i386 => x86/x86}/legacy.c (89%)
 create mode 100644 rtemsbsd/i386/include/machine/clock.h
 create mode 100644 rtemsbsd/include/rtems/bsd/local/opt_acpi.h
 create mode 100644 rtemsbsd/include/x86/legacyvar.h
 create mode 100644 rtemsbsd/include/x86/specialreg.h
 create mode 100644 rtemsbsd/include/x86/x86_var.h
2.12.3
