[PATCH v4 0/3] [rtems-libbsd] Fix compilation for amd64
Jan Sommer jan.sommer at dlr.de
Tue Feb 18 10:21:41 UTC 2020
Similar to the previous patchset for i386 this one enables compilation for the amd64 BSP with the following limitations:
- dev_nic_e1000 needs to be off
- debugger01.exe does not link because the amd64 bsp has no libdebugger support
I tried to use the lessons learned from the last patch set.
It does not seem to affect arm, sparc and i386 compilation.
Made a mistake and started to send with v3, so I will increment from
there to keep consecutive numbers.
Version 4:
- Added a path-mapping mechanism to waf_libbsd.py and libbsd.py
- Removed the "if cpu == " switches from waf_libbsd.py
Best regards,
    Jan
Jan Sommer (3):
  amd64: Add missing files from FreeBSD
  amd64: Add to build
  amd64: Port to RTEMS
 freebsd/sys/amd64/amd64/in_cksum.c            |  245 ++++
 freebsd/sys/amd64/include/machine/_bus.h      |   48 +
 freebsd/sys/amd64/include/machine/cpufunc.h   | 1053 +++++++++++++++++
 freebsd/sys/amd64/include/machine/efi.h       |   78 ++
 freebsd/sys/amd64/include/machine/in_cksum.h  |   86 ++
 freebsd/sys/amd64/include/machine/md_var.h    |   90 ++
 .../sys/amd64/include/machine/specialreg.h    |    6 +
 freebsd/sys/sys/efi.h                         |  198 ++++
 libbsd.py                                     |   25 +
 rtemsbsd/amd64/include/machine/clock.h        |    2 +
 waf_libbsd.py                                 |   13 +-
 11 files changed, 1842 insertions(+), 2 deletions(-)
 create mode 100644 freebsd/sys/amd64/amd64/in_cksum.c
 create mode 100644 freebsd/sys/amd64/include/machine/_bus.h
 create mode 100644 freebsd/sys/amd64/include/machine/cpufunc.h
 create mode 100644 freebsd/sys/amd64/include/machine/efi.h
 create mode 100644 freebsd/sys/amd64/include/machine/in_cksum.h
 create mode 100644 freebsd/sys/amd64/include/machine/md_var.h
 create mode 100644 freebsd/sys/amd64/include/machine/specialreg.h
 create mode 100644 freebsd/sys/sys/efi.h
 create mode 100644 rtemsbsd/amd64/include/machine/clock.h
2.17.1
