[PATCH 2/5] user/tools/tester.rst: Removes wrong reference to GDB
clrrm at isep.ipp.pt clrrm at isep.ipp.pt
Thu Apr 9 14:34:10 UTC 2020
 user/tools/tester.rst | 3 ---
 1 file changed, 3 deletions(-)
diff --git a/user/tools/tester.rst b/user/tools/tester.rst
index b77240b..c07fc49 100644
--- a/user/tools/tester.rst
+++ b/user/tools/tester.rst
@@ -259,9 +259,6 @@ You can see your executable running in the first terminal.
 For more information on the sis simulator refer to this doc: https://gaisler.se/sis/sis.pdf
-The command ``r`` is used to debug set break points before issuing the GDB
-``run`` command.
 There are currently close to 500 separate tests and you can run them all with a
 single RTEMS Tester command.
2.17.1
