[PATCH 3/5] user/tools/tester.rst: Clarifies the need of --rtems-tools in rtems-test command line
clrrm at isep.ipp.pt
Thu Apr 9 14:34:11 UTC 2020
user/tools/tester.rst | 14 ++++++++------
1 file changed, 8 insertions(+), 6 deletions(-)
diff --git a/user/tools/tester.rst b/user/tools/tester.rst
index c07fc49..9f9933a 100644
--- a/user/tools/tester.rst
+++ b/user/tools/tester.rst
@@ -280,7 +280,6 @@ BSP build tree:
$ ~/development/rtems/test/rtems-tools.git/tester/rtems-test \
--log=log_erc32_run \
--rtems-bsp=erc32-run \
- --rtems-tools=$HOME/development/rtems/5 \
sparc-rtems5/c/erc32/testsuites/samples
RTEMS Testing - Tester, 5.not_released
[ 1/13] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 | sparc/erc32: base_sp.exe
@@ -316,7 +315,6 @@ appearance above, we have the following:
* The ``--log`` option sends the output to a log file. By default only failed
tests log the complete output.
* The ``--rtems-bsp`` option selects the erc32 BSP.
-* The path to the RTEMS tools so GDB can be found.
* The path to the erc32 BSP tests to run. If you add subdirectories
to the path specific tests can be run.
* The test results so far. See details below.
@@ -332,10 +330,14 @@ appearance above, we have the following:
``sparc-rtems5/c/erc32/testsuites/samples`` then all the executables
would have been tested and not just those in samples.
-This BSP requires the ``--rtems-tools`` option because the SPARC GDB is the
-``sparc-rtems4.11-gdb`` command that is part of the RTEMS tools. Not every BSP
-will require this option so you will need to check the specifics of the BSP
-configuration you are using in order to determine if it is needed.
+.. note:: Some BSPs require the use of the specific target architecture GDB
+ command (e.g. RTEMS 5 SPARC GDB command is ``sparc-rtems5-gdb``).
+ As this command is part of the RTEMS tools, the ``--rtems-tools``
+ option should be added to the ``rtems-test`` command line, e.g.
+ ``--rtems-tools=$HOME/development/rtems/5``.
+ Not every BSP requires this option so you will need to check the
+ specifics of the BSP configuration you are using in order to
+ determine if this option is needed.
An output line is printed for each test that is executed. The :program:`rtems-test`
command by default runs multiple tests in parallel so you will see a number
2.17.1
