Test for timer_create() with CLOCK_MONOTONIC
Joel Sherrill
joel at rtems.org
Thu Apr 9 17:17:11 UTC 2020
On Thu, Apr 9, 2020 at 12:14 PM Eshan Dhawan <eshandhawan51 at gmail.com>
wrote:
> hello,
> where would the test case of timer_create() with CLOCK_MONOTONIC be added
> would they be added in
> psxtimer01 or psxtimer02 or will it be required to create a new test file
> for that?
I would probably just create a new test for this. But this is also one you
could easily add to
one of the existing tests if they aren't huge already.
--joel
> thanks
> - Eshan
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200409/c05a23fe/attachment.html>
