Test for timer_create() with CLOCK_MONOTONIC
Eshan Dhawan eshandhawan51 at gmail.com
Thu Apr 9 17:31:44 UTC 2020
On Thu, Apr 9, 2020 at 10:47 PM Joel Sherrill <joel at rtems.org> wrote:
> On Thu, Apr 9, 2020 at 12:14 PM Eshan Dhawan <eshandhawan51 at gmail.com>
> wrote:
>> hello,
>> where would the test case of timer_create() with CLOCK_MONOTONIC be added
>> would they be added in
>> psxtimer01 or psxtimer02 or will it be required to create a new test file
>> for that?
> I would probably just create a new test for this. But this is also one you
> could easily add to
> one of the existing tests if they aren't huge already.
psxtimer01 is complicated to work on
But it can be added to psxtimer02
the test is not that long and not that complicated either
-Eshan
> --joel
>> thanks
>> - Eshan
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200409/fb8c9ffb/attachment-0001.html>
