[PATCH v2] Tests for pthread_getcpuclockid method. Ticket:3891
Eshan dhawan
eshandhawan51 at gmail.com
Thu Apr 9 20:30:17 UTC 2020
testsuites/psxtests/Makefile.am | 10 ++
testsuites/psxtests/configure.ac | 1 +
testsuites/psxtests/psxgetcpuclockid01/init.c | 120 ++++++++++++++++++
.../psxgetcpuclockid01/psxgetcpuclockid01.doc | 19 +++
.../psxgetcpuclockid01/psxgetcpuclockid01.scn | 4 +
5 files changed, 154 insertions(+)
create mode 100644 testsuites/psxtests/psxgetcpuclockid01/init.c
create mode 100644 testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.doc
create mode 100644 testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.scn
diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
index 1f9e4233ec..ffadff16e7 100755
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -462,6 +462,16 @@ psxgetattrnp01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxgetattrnp01) \
$(support_includes) -I$(top_srcdir)/include
endif
+if TEST_psxgetcpuclockid01
+psx_tests += psxgetcpuclockid01
+psx_screens += psxgetcpuclockid01/psxgetcpuclockid01.scn
+psx_docs += psxgetcpuclockid01/psxgetcpuclockid01.doc
+psxgetcpuclockid01_SOURCES = psxgetcpuclockid01/init.c
+psxgetcpuclockid01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxgetcpuclockid01) \
+ $(support_includes)
+endif
if TEST_psxgetrusage01
psx_tests += psxgetrusage01
psx_screens += psxgetrusage01/psxgetrusage01.scn
diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/configure.ac
index 139787cccb..c509086abc 100644
--- a/testsuites/psxtests/configure.ac
+++ b/testsuites/psxtests/configure.ac
@@ -91,6 +91,7 @@ RTEMS_TEST_CHECK([psxfile01])
RTEMS_TEST_CHECK([psxfile02])
RTEMS_TEST_CHECK([psxfilelock01])
RTEMS_TEST_CHECK([psxgetattrnp01])
+RTEMS_TEST_CHECK([psxgetcpuclockid01])
RTEMS_TEST_CHECK([psxgetrusage01])
RTEMS_TEST_CHECK([psxglobalcon01])
RTEMS_TEST_CHECK([psxglobalcon02])
diff --git a/testsuites/psxtests/psxgetcpuclockid01/init.c b/testsuites/psxtests/psxgetcpuclockid01/init.c
new file mode 100644
index 0000000000..8e1093e44b
--- /dev/null
+++ b/testsuites/psxtests/psxgetcpuclockid01/init.c
@@ -0,0 +1,120 @@
+ * @file
+ * @brief Test suite for getcpuclockid methods
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2020 Eshan Dhawan
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <errno.h>
+#include <pthread.h>
+#include <stdint.h>
+#include <rtems/test.h>
+#include <sys/utsname.h>
+#include <unistd.h>
+#include <errno.h>
+#include <sched.h>
+#include <rtems/score/todimpl.h>
+#include <rtems/score/threadimpl.h>
+#include "tmacros.h"
+const char rtems_test_name[] = "PSXGETCPUCLOCKID 1";
+/* Forward declaration to avoid warnings */
+rtems_task Init(rtems_task_argument ignored);
+void *test_pthread(void *);
+/* test_task function begins */
+void *test_pthread(void *arg)
+ int r;
+ clockid_t cid;
+ r = pthread_getcpuclockid( pthread_self(), &cid );
+ if(r)
+ printf( "pthread_getcpuclockid : 0x%d", r );
+ rtems_test_assert( r == 0 );
+ pthread_exit(0);
+ return NULL;
+/* init test function begins */
+ TEST_BEGIN();
+ int r;
+ clockid_t cid;
+ pthread_t thread_id;
+ r= pthread_create( &thread_id, NULL, test_pthread, NULL );
+ if( r )
+ printf( "pthread_create : 0x%d", r );
+ r = pthread_join( thread_id, NULL );
+ if( r )
+ printf( "pthread_join : 0x%d", r );
+ r = pthread_getcpuclockid( thread_id, &cid );
+ if( r != ESRCH )
+ rtems_test_assert( r == ESRCH );
+ TEST_END();
+ rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_POSIX_THREADS 2
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.doc b/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.doc
index 0000000000..145f009337
--- /dev/null
+++ b/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.doc
@@ -0,0 +1,19 @@
+# COPYRIGHT (c) 2020
+# On-Line Applications Research Corporation (OAR).
+# SPDX-License-Identifier: BSD-2-Clause
+This file describes the directives and concepts tested by this test set.
+test set name: psxgetcpuclockid 1
+Directives:
+ Pthread_getcpuclockid()
+Concepts:
++ This test exercises the getcpuclockid methods.
++ For pthread_getcpuclockid it created a pthread using pthread_create and then finds
+the clockid_t of that thread and then ends the thread.
+After the thread is ended it again tried to find the clockid_t of the thread to check
+for ESRCH exception.
diff --git a/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.scn b/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.scn
index 0000000000..937a908fd5
--- /dev/null
+++ b/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.scn
@@ -0,0 +1,4 @@
+*** BEGIN OF TEST PSXGETCLOCKID 1 ***
+*** END OF TEST PSXGETCPUCLOCKID 1 ***
2.17.1
