[PATCH v2] Tests for pthread_getcpuclockid method. Ticket:3891
Eshan Dhawan eshandhawan51 at gmail.com
Mon Apr 13 16:14:02 UTC 2020
Hello everyone,
I sent this patch regarding adding a test for pthread_getcpuclockid method
a few days ago.
If someone could test it.
thanks
-Eshan
On Fri, Apr 10, 2020 at 2:00 AM Eshan dhawan <eshandhawan51 at gmail.com>
wrote:
>  testsuites/psxtests/Makefile.am               |  10 ++
>  testsuites/psxtests/configure.ac              |   1 +
>  testsuites/psxtests/psxgetcpuclockid01/init.c | 120 ++++++++++++++++++
>  .../psxgetcpuclockid01/psxgetcpuclockid01.doc |  19 +++
>  .../psxgetcpuclockid01/psxgetcpuclockid01.scn |   4 +
>  5 files changed, 154 insertions(+)
>  create mode 100644 testsuites/psxtests/psxgetcpuclockid01/init.c
>  create mode 100644
> testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.doc
>  create mode 100644
> testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.scn
> diff --git a/testsuites/psxtests/Makefile.am
> b/testsuites/psxtests/Makefile.am
> index 1f9e4233ec..ffadff16e7 100755
> --- a/testsuites/psxtests/Makefile.am
> +++ b/testsuites/psxtests/Makefile.am
> @@ -462,6 +462,16 @@ psxgetattrnp01_CPPFLAGS = $(AM_CPPFLAGS)
> $(TEST_FLAGS_psxgetattrnp01) \
>         $(support_includes) -I$(top_srcdir)/include
>  endif
> +if TEST_psxgetcpuclockid01
> +psx_tests += psxgetcpuclockid01
> +psx_screens += psxgetcpuclockid01/psxgetcpuclockid01.scn
> +psx_docs += psxgetcpuclockid01/psxgetcpuclockid01.doc
> +psxgetcpuclockid01_SOURCES = psxgetcpuclockid01/init.c
> +psxgetcpuclockid01_CPPFLAGS = $(AM_CPPFLAGS)
> $(TEST_FLAGS_psxgetcpuclockid01) \
> +       $(support_includes)
> +endif
>  if TEST_psxgetrusage01
>  psx_tests += psxgetrusage01
>  psx_screens += psxgetrusage01/psxgetrusage01.scn
> diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/
> configure.ac
> index 139787cccb..c509086abc 100644
> --- a/testsuites/psxtests/configure.ac
> +++ b/testsuites/psxtests/configure.ac
> @@ -91,6 +91,7 @@ RTEMS_TEST_CHECK([psxfile01])
>  RTEMS_TEST_CHECK([psxfile02])
>  RTEMS_TEST_CHECK([psxfilelock01])
>  RTEMS_TEST_CHECK([psxgetattrnp01])
> +RTEMS_TEST_CHECK([psxgetcpuclockid01])
>  RTEMS_TEST_CHECK([psxgetrusage01])
>  RTEMS_TEST_CHECK([psxglobalcon01])
>  RTEMS_TEST_CHECK([psxglobalcon02])
> diff --git a/testsuites/psxtests/psxgetcpuclockid01/init.c
> b/testsuites/psxtests/psxgetcpuclockid01/init.c
> new file mode 100644
> index 0000000000..8e1093e44b
> --- /dev/null
> +++ b/testsuites/psxtests/psxgetcpuclockid01/init.c
> @@ -0,0 +1,120 @@
> + *  @file
> + *  @brief Test suite for getcpuclockid methods
> + * SPDX-License-Identifier: BSD-2-Clause
> + * Copyright (C) 2020 Eshan Dhawan
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS
> BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
> THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <errno.h>
> +#include <pthread.h>
> +#include <stdint.h>
> +#include <rtems/test.h>
> +#include <sys/utsname.h>
> +#include <unistd.h>
> +#include <errno.h>
> +#include <sched.h>
> +#include <rtems/score/todimpl.h>
> +#include <rtems/score/threadimpl.h>
> +#include "tmacros.h"
> +const char rtems_test_name[] = "PSXGETCPUCLOCKID 1";
> +/* Forward declaration to avoid warnings */
> +rtems_task Init(rtems_task_argument ignored);
> +void *test_pthread(void *);
> +/* test_task function begins */
> +void *test_pthread(void *arg)
> +  int r;
> +  clockid_t cid;
> +  r = pthread_getcpuclockid( pthread_self(), &cid );
> +  if(r)
> +    printf( "pthread_getcpuclockid : 0x%d", r );
> +  rtems_test_assert( r == 0 );
> +  pthread_exit(0);
> +  return NULL;
> +/* init test function begins */
> +  TEST_BEGIN();
> +  int r;
> +  clockid_t cid;
> +  pthread_t thread_id;
> +  r= pthread_create( &thread_id, NULL, test_pthread, NULL );
> +  if( r )
> +    printf( "pthread_create : 0x%d", r );
> + r = pthread_join( thread_id, NULL );
> +  if( r )
> +    printf( "pthread_join : 0x%d", r );
> +  r = pthread_getcpuclockid( thread_id, &cid );
> +  if( r != ESRCH )
> +  rtems_test_assert( r == ESRCH );
> +  TEST_END();
> +  rtems_test_exit(0);
> +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> +#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
> +#define CONFIGURE_MAXIMUM_POSIX_THREADS     2
> +#define CONFIGURE_MAXIMUM_TASKS 1
> +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> +#include <rtems/confdefs.h>
> diff --git a/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.doc
> b/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.doc
> index 0000000000..145f009337
> --- /dev/null
> +++ b/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.doc
> @@ -0,0 +1,19 @@
> +#  COPYRIGHT (c) 2020
> +#  On-Line Applications Research Corporation (OAR).
> +# SPDX-License-Identifier: BSD-2-Clause
> +This file describes the directives and concepts tested by this test set.
> +test set name:  psxgetcpuclockid 1
> +Directives:
> +  Pthread_getcpuclockid()
> +Concepts:
> ++ This test exercises the getcpuclockid methods.
> ++ For pthread_getcpuclockid it created a pthread using pthread_create and
> then finds
> +the clockid_t of that thread and then ends the thread.
> +After the thread is ended it again tried to find the clockid_t of the
> thread to check
> +for ESRCH exception.
> diff --git a/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.scn
> b/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.scn
> index 0000000000..937a908fd5
> --- /dev/null
> +++ b/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.scn
> @@ -0,0 +1,4 @@
> +*** BEGIN OF TEST PSXGETCLOCKID 1 ***
> +*** END OF TEST PSXGETCPUCLOCKID 1 ***
> 2.17.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200413/d029ef7b/attachment-0001.html>
