Test for timer_create() with CLOCK_MONOTONIC
Gedare Bloom
gedare at rtems.org
Fri Apr 10 04:05:29 UTC 2020
Please read the other thread "Test for clock_nanosleep with
CLOCK_MONOTONIC (# 3890)"
Have a look at the RTEMS Test Framework.
On Thu, Apr 9, 2020 at 11:31 AM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
> On Thu, Apr 9, 2020 at 10:47 PM Joel Sherrill <joel at rtems.org> wrote:
>> On Thu, Apr 9, 2020 at 12:14 PM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
>>> hello,
>>> where would the test case of timer_create() with CLOCK_MONOTONIC be added ??
>>> would they be added in
>>> psxtimer01 or psxtimer02 or will it be required to create a new test file for that?
>> I would probably just create a new test for this. But this is also one you could easily add to
>> one of the existing tests if they aren't huge already.
> psxtimer01 is complicated to work on
> But it can be added to psxtimer02
> the test is not that long and not that complicated either
> -Eshan
>> --joel
>>> thanks
>>> - Eshan
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
