[PATCH 0/0] Clang/LLVM for RTEMS Waf Build
Hesham Almatary
hesham.almatary at cl.cam.ac.uk
Fri Apr 10 11:57:00 UTC 2020
Hello Suyash,
These patches aren't for upstream RTEMS, so it's not relevant to your
project/query.
That said, I am not sure what you are trying to do. Are you trying to
build/cross-compile RTEMS itself with Clang?
On Fri, 10 Apr 2020 at 12:17, suyash singh <suyashsingh234 at gmail.com> wrote:
> Now I can run scan-build from clang/llvm?
> Earlier I got error
> [image: image.png]
> In earlier mail you suggested me to use
> [1] https://github.com/CTSRD-CHERI/llvm-project
> [2]
> https://github.com/RTEMS/rtems/blob/d582d0e130a463842e27070a2e85ebc1acc7b71f/bsps/riscv/riscv/config/rv32iac_clang.cfg#L8
> to build RISC-V
> On Fri, Apr 10, 2020 at 4:09 PM Hesham Almatary <
> hesham.almatary at cl.cam.ac.uk> wrote:
>> Hello,
>> The following set of patches are a few fixes and added support to
>> build RTEMS with Clang/LLVM from the new Waf build system, with RISC-V
>> as the main target architecture.
>> Best,
>> Hesham
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200410/d420300a/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200410/d420300a/attachment-0001.png>
