[PATCH 0/0] Clang/LLVM for RTEMS Waf Build
suyash singh
suyashsingh234 at gmail.com
Fri Apr 10 12:24:08 UTC 2020
Hello,
As part of my proposed Gsoc,
I am trying to integrate clang static analyzer and UBSan in rtems.
Both of them work with the build process of a project
On Fri, Apr 10, 2020, 5:23 PM Hesham Almatary <hesham.almatary at cl.cam.ac.uk>
wrote:
> Hello Suyash,
> These patches aren't for upstream RTEMS, so it's not relevant to your
> project/query.
> That said, I am not sure what you are trying to do. Are you trying to
> build/cross-compile RTEMS itself with Clang?
> On Fri, 10 Apr 2020 at 12:17, suyash singh <suyashsingh234 at gmail.com>
> wrote:
>> Now I can run scan-build from clang/llvm?
>> Earlier I got error
>> [image: image.png]
>> In earlier mail you suggested me to use
>> [1] https://github.com/CTSRD-CHERI/llvm-project
>> [2]
>> https://github.com/RTEMS/rtems/blob/d582d0e130a463842e27070a2e85ebc1acc7b71f/bsps/riscv/riscv/config/rv32iac_clang.cfg#L8
>> to build RISC-V
>> On Fri, Apr 10, 2020 at 4:09 PM Hesham Almatary <
>> hesham.almatary at cl.cam.ac.uk> wrote:
>>> Hello,
>>> The following set of patches are a few fixes and added support to
>>> build RTEMS with Clang/LLVM from the new Waf build system, with RISC-V
>>> as the main target architecture.
>>> Best,
>>> Hesham
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200410/69dfeeef/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200410/69dfeeef/attachment-0001.png>
