[PATCH v2] bsp/raspberrypi: Fix build warnings.
Fri Apr 10 13:29:01 UTC 2020
Pushed.
I'm sorry. It is surprising but working  from home seems to create even
more work than being in the office. I am swamped. :(
--joel
On Fri, Apr 10, 2020 at 7:59 AM Niteesh G. S. <niteesh.gs at gmail.com> wrote:
> This patch has been unnoticed for a while.
> If the lack of testing is what is stopping from pushing it I am happy
> to test it on real hardware.
> But I can't come up with a good methodology for testing it.
> My initial thoughts were to generate a GPIO interrupt with no ISR.
> This would cause the default ISR to be called. But I am not familiar
> with RTEMS interrupt mechanism so I don't know if this would work or not.
> If this is a wrong way to test it, then please let me know of the
> right way.
> Thanks,
> Niteesh.
> On Tue, Mar 31, 2020 at 4:21 AM Gedare Bloom <gedare at rtems.org> wrote:
>> This looks right but I'm not able to try it out.
>> On Sat, Mar 28, 2020 at 12:24 PM G S Niteesh Babu <niteesh.gs at gmail.com>
>> wrote:
>> > 1) _Memory_Initialize makes pointer from integer
>> >         without a cast.
>> > 2) printf format error, expects %u but %lu provided.
>> >  bsps/arm/raspberrypi/irq/irq.c             | 4 +++-
>> >  bsps/arm/raspberrypi/start/bspstarthooks.c | 2 ++
>> >  2 files changed, 5 insertions(+), 1 deletion(-)
>> > diff --git a/bsps/arm/raspberrypi/irq/irq.c
>> b/bsps/arm/raspberrypi/irq/irq.c
>> > index 9e1bcfc1bc..835cdf97d9 100644
>> > --- a/bsps/arm/raspberrypi/irq/irq.c
>> > +++ b/bsps/arm/raspberrypi/irq/irq.c
>> > @@ -32,6 +32,8 @@
>> >  #include <rtems/bspIo.h>
>> >  #include <strings.h>
>> > +#include <rtems/inttypes.h>
>> >  #ifdef RTEMS_SMP
>> >  #include <rtems/score/smp.h>
>> >  #include <rtems/score/smpimpl.h>
>> > @@ -157,7 +159,7 @@ void
>> bsp_interrupt_vector_disable(rtems_vector_number vector)
>> >  void bsp_interrupt_handler_default(rtems_vector_number vector)
>> > -    printk("spurious interrupt: %lu\n", vector);
>> > +    printk("spurious interrupt: %" PRIdrtems_vector_number "\n",
>> vector);
>> >  rtems_status_code bsp_interrupt_facility_initialize(void)
>> > diff --git a/bsps/arm/raspberrypi/start/bspstarthooks.c
>> b/bsps/arm/raspberrypi/start/bspstarthooks.c
>> > index fd6aa53059..eb6546db1c 100644
>> > --- a/bsps/arm/raspberrypi/start/bspstarthooks.c
>> > +++ b/bsps/arm/raspberrypi/start/bspstarthooks.c
>> > @@ -184,7 +184,9 @@ static void bsp_memory_initialize(void)
>> >    _Memory_Initialize(
>> >      &_Memory_Areas[0],
>> > +    (void *)
>> raspberrypi_mmu_config_table[ARMV7_CP15_START_WORKSPACE_ENTRY_INDEX].begin,
>> > +    (void *)
>> raspberrypi_mmu_config_table[ARMV7_CP15_START_WORKSPACE_ENTRY_INDEX].end
>> > 2.17.1
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200410/d96464cb/attachment.html>
