[PATCH v2] bsp/raspberrypi: Fix build warnings.
Niteesh G. S.
niteesh.gs at gmail.com
Fri Apr 10 12:58:36 UTC 2020
This patch has been unnoticed for a while.
If the lack of testing is what is stopping from pushing it I am happy
to test it on real hardware.
But I can't come up with a good methodology for testing it.
My initial thoughts were to generate a GPIO interrupt with no ISR.
This would cause the default ISR to be called. But I am not familiar
with RTEMS interrupt mechanism so I don't know if this would work or not.
If this is a wrong way to test it, then please let me know of the
right way.
Thanks,
Niteesh.
On Tue, Mar 31, 2020 at 4:21 AM Gedare Bloom <gedare at rtems.org> wrote:
> This looks right but I'm not able to try it out.
> On Sat, Mar 28, 2020 at 12:24 PM G S Niteesh Babu <niteesh.gs at gmail.com>
> wrote:
> > 1) _Memory_Initialize makes pointer from integer
> > without a cast.
> > 2) printf format error, expects %u but %lu provided.
> > bsps/arm/raspberrypi/irq/irq.c | 4 +++-
> > bsps/arm/raspberrypi/start/bspstarthooks.c | 2 ++
> > 2 files changed, 5 insertions(+), 1 deletion(-)
> > diff --git a/bsps/arm/raspberrypi/irq/irq.c
> b/bsps/arm/raspberrypi/irq/irq.c
> > index 9e1bcfc1bc..835cdf97d9 100644
> > --- a/bsps/arm/raspberrypi/irq/irq.c
> > +++ b/bsps/arm/raspberrypi/irq/irq.c
> > @@ -32,6 +32,8 @@
> > #include <rtems/bspIo.h>
> > #include <strings.h>
> > +#include <rtems/inttypes.h>
> > #ifdef RTEMS_SMP
> > #include <rtems/score/smp.h>
> > #include <rtems/score/smpimpl.h>
> > @@ -157,7 +159,7 @@ void
> bsp_interrupt_vector_disable(rtems_vector_number vector)
> > void bsp_interrupt_handler_default(rtems_vector_number vector)
> > - printk("spurious interrupt: %lu\n", vector);
> > + printk("spurious interrupt: %" PRIdrtems_vector_number "\n",
> vector);
> > rtems_status_code bsp_interrupt_facility_initialize(void)
> > diff --git a/bsps/arm/raspberrypi/start/bspstarthooks.c
> b/bsps/arm/raspberrypi/start/bspstarthooks.c
> > index fd6aa53059..eb6546db1c 100644
> > --- a/bsps/arm/raspberrypi/start/bspstarthooks.c
> > +++ b/bsps/arm/raspberrypi/start/bspstarthooks.c
> > @@ -184,7 +184,9 @@ static void bsp_memory_initialize(void)
> > _Memory_Initialize(
> > &_Memory_Areas[0],
> > + (void *)
> raspberrypi_mmu_config_table[ARMV7_CP15_START_WORKSPACE_ENTRY_INDEX].begin,
> > + (void *)
> raspberrypi_mmu_config_table[ARMV7_CP15_START_WORKSPACE_ENTRY_INDEX].end
> > 2.17.1
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200410/3a616694/attachment.html>
