[PATCH 2/2] score: Check time of day in _TOD_Set()
Sebastian Huber
Mon Apr 13 17:51:17 UTC 2020
Close #3949.
cpukit/posix/src/clocksettime.c | 3 ---
cpukit/score/src/coretodset.c | 21 ++++++++++++++++++++-
testsuites/psxtests/psxclock/init.c | 25 +++++++++++++++++++++++++
3 files changed, 45 insertions(+), 4 deletions(-)
diff --git a/cpukit/posix/src/clocksettime.c b/cpukit/posix/src/clocksettime.c
index 5bb6f2f14b..49e4761875 100644
--- a/cpukit/posix/src/clocksettime.c
+++ b/cpukit/posix/src/clocksettime.c
@@ -40,9 +40,6 @@ int clock_settime(
if ( clock_id == CLOCK_REALTIME ) {
ISR_lock_Context lock_context;
- if ( tp->tv_sec < TOD_SECONDS_1970_THROUGH_1988 )
- rtems_set_errno_and_return_minus_one( EINVAL );
_TOD_Lock();
_TOD_Acquire( &lock_context );
status = _TOD_Set( tp, &lock_context );
diff --git a/cpukit/score/src/coretodset.c b/cpukit/score/src/coretodset.c
index ed840ece2b..b9a745d9b4 100644
--- a/cpukit/score/src/coretodset.c
+++ b/cpukit/score/src/coretodset.c
@@ -22,6 +22,25 @@
+static Status_Control _TOD_Check_time_of_day_and_run_hooks(
+ const struct timespec *tod
+ if ( !_Watchdog_Is_valid_timespec( tod ) ) {
+ return STATUS_INVALID_NUMBER;
+ if ( tod->tv_sec < TOD_SECONDS_1970_THROUGH_1988 ) {
+ if ( _Watchdog_Is_far_future_timespec( tod ) ) {
+ return _TOD_Hook_Run( TOD_ACTION_SET_CLOCK, tod );
Status_Control _TOD_Set(
const struct timespec *tod,
ISR_lock_Context *lock_context
@@ -35,7 +54,7 @@ Status_Control _TOD_Set(
_Assert( _TOD_Is_owner() );
- status = _TOD_Hook_Run( TOD_ACTION_SET_CLOCK, tod );
+ status = _TOD_Check_time_of_day_and_run_hooks( tod );
if ( status != STATUS_SUCCESSFUL ) {
_TOD_Release( lock_context );
return status;
diff --git a/testsuites/psxtests/psxclock/init.c b/testsuites/psxtests/psxclock/init.c
index 40c224cec4..778637b4fd 100644
--- a/testsuites/psxtests/psxclock/init.c
+++ b/testsuites/psxtests/psxclock/init.c
@@ -96,16 +96,19 @@ static rtems_task Init(
/* error cases in clock_gettime and clock_settime */
puts( "Init: clock_gettime - EINVAL (NULL timespec)" );
+ errno = 0;
sc = clock_gettime( CLOCK_REALTIME, NULL );
rtems_test_assert( sc == -1 );
rtems_test_assert( errno == EINVAL );
puts( "Init: clock_gettime - EINVAL (invalid clockid)" );
+ errno = 0;
sc = clock_gettime( (clockid_t)-1, &tv );
puts( "Init: clock_settime - EINVAL (invalid clockid)" );
+ errno = 0;
sc = clock_settime( (clockid_t)-1, &tv );
@@ -115,6 +118,23 @@ static rtems_task Init(
tv.tv_nsec = 0;
printf( ctime( &tv.tv_sec ) );
puts( "Init: clock_settime - before 1988 EINVAL" );
+ errno = 0;
+ sc = clock_settime( CLOCK_REALTIME, &tv );
+ rtems_test_assert( sc == -1 );
+ rtems_test_assert( errno == EINVAL );
+ puts( "Init: clock_settime - invalid nanoseconds EINVAL" );
+ tv.tv_sec = 946681200;
+ tv.tv_nsec = 2000000000;
+ errno = 0;
+ puts( "Init: clock_settime - far future EINVAL" );
+ tv.tv_sec = 17179869184;
+ tv.tv_nsec = 0;
+ errno = 0;
@@ -122,11 +142,13 @@ static rtems_task Init(
/* exercise clock_getres */
puts( "Init: clock_getres - EINVAL (invalid clockid)" );
+ errno = 0;
sc = clock_getres( (clockid_t) -1, &tv );
puts( "Init: clock_getres - EINVAL (NULL resolution)" );
+ errno = 0;
sc = clock_getres( CLOCK_REALTIME, NULL );
@@ -196,6 +218,7 @@ static rtems_task Init(
tv.tv_sec = 0;
tv.tv_nsec = TOD_NANOSECONDS_PER_SECOND * 2;
puts( "Init: nanosleep - EINVAL (too many nanoseconds)" );
+ errno = 0;
sc = nanosleep ( &tv, &tr );
@@ -204,6 +227,7 @@ static rtems_task Init(
tv.tv_sec = -1;
tv.tv_nsec = 0;
puts( "Init: nanosleep - negative seconds - EINVAL" );
+ errno = 0;
@@ -212,6 +236,7 @@ static rtems_task Init(
tv.tv_sec = 0;
tv.tv_nsec = -1;
puts( "Init: nanosleep - negative nanoseconds - EINVAL" );
+ errno = 0;
2.16.4
