[PATCH 2/2] score: Check time of day in _TOD_Set()
Gedare Bloom
gedare at rtems.org
Mon Apr 13 20:08:32 UTC 2020
These 2 patches look good to me.
On Mon, Apr 13, 2020 at 11:51 AM Sebastian Huber
> Close #3949.
> cpukit/posix/src/clocksettime.c | 3 ---
> cpukit/score/src/coretodset.c | 21 ++++++++++++++++++++-
> testsuites/psxtests/psxclock/init.c | 25 +++++++++++++++++++++++++
> 3 files changed, 45 insertions(+), 4 deletions(-)
> diff --git a/cpukit/posix/src/clocksettime.c b/cpukit/posix/src/clocksettime.c
> index 5bb6f2f14b..49e4761875 100644
> --- a/cpukit/posix/src/clocksettime.c
> +++ b/cpukit/posix/src/clocksettime.c
> @@ -40,9 +40,6 @@ int clock_settime(
> if ( clock_id == CLOCK_REALTIME ) {
> ISR_lock_Context lock_context;
> - if ( tp->tv_sec < TOD_SECONDS_1970_THROUGH_1988 )
> - rtems_set_errno_and_return_minus_one( EINVAL );
> _TOD_Lock();
> _TOD_Acquire( &lock_context );
> status = _TOD_Set( tp, &lock_context );
> diff --git a/cpukit/score/src/coretodset.c b/cpukit/score/src/coretodset.c
> index ed840ece2b..b9a745d9b4 100644
> --- a/cpukit/score/src/coretodset.c
> +++ b/cpukit/score/src/coretodset.c
> @@ -22,6 +22,25 @@
> #include <rtems/score/assert.h>
> #include <rtems/score/watchdogimpl.h>
> +static Status_Control _TOD_Check_time_of_day_and_run_hooks(
> + const struct timespec *tod
> + if ( !_Watchdog_Is_valid_timespec( tod ) ) {
> + return STATUS_INVALID_NUMBER;
> + if ( tod->tv_sec < TOD_SECONDS_1970_THROUGH_1988 ) {
> + if ( _Watchdog_Is_far_future_timespec( tod ) ) {
> + return _TOD_Hook_Run( TOD_ACTION_SET_CLOCK, tod );
> Status_Control _TOD_Set(
> const struct timespec *tod,
> ISR_lock_Context *lock_context
> @@ -35,7 +54,7 @@ Status_Control _TOD_Set(
> _Assert( _TOD_Is_owner() );
> - status = _TOD_Hook_Run( TOD_ACTION_SET_CLOCK, tod );
> + status = _TOD_Check_time_of_day_and_run_hooks( tod );
> if ( status != STATUS_SUCCESSFUL ) {
> _TOD_Release( lock_context );
> return status;
> diff --git a/testsuites/psxtests/psxclock/init.c b/testsuites/psxtests/psxclock/init.c
> index 40c224cec4..778637b4fd 100644
> --- a/testsuites/psxtests/psxclock/init.c
> +++ b/testsuites/psxtests/psxclock/init.c
> @@ -96,16 +96,19 @@ static rtems_task Init(
> /* error cases in clock_gettime and clock_settime */
> puts( "Init: clock_gettime - EINVAL (NULL timespec)" );
> + errno = 0;
> sc = clock_gettime( CLOCK_REALTIME, NULL );
> rtems_test_assert( sc == -1 );
> rtems_test_assert( errno == EINVAL );
> puts( "Init: clock_gettime - EINVAL (invalid clockid)" );
> + errno = 0;
> sc = clock_gettime( (clockid_t)-1, &tv );
> puts( "Init: clock_settime - EINVAL (invalid clockid)" );
> + errno = 0;
> sc = clock_settime( (clockid_t)-1, &tv );
> @@ -115,6 +118,23 @@ static rtems_task Init(
> tv.tv_nsec = 0;
> printf( ctime( &tv.tv_sec ) );
> puts( "Init: clock_settime - before 1988 EINVAL" );
> + errno = 0;
> + sc = clock_settime( CLOCK_REALTIME, &tv );
> + rtems_test_assert( sc == -1 );
> + rtems_test_assert( errno == EINVAL );
> + puts( "Init: clock_settime - invalid nanoseconds EINVAL" );
> + tv.tv_sec = 946681200;
> + tv.tv_nsec = 2000000000;
> + errno = 0;
> + puts( "Init: clock_settime - far future EINVAL" );
> + tv.tv_sec = 17179869184;
> + tv.tv_nsec = 0;
> + errno = 0;
> @@ -122,11 +142,13 @@ static rtems_task Init(
> /* exercise clock_getres */
> puts( "Init: clock_getres - EINVAL (invalid clockid)" );
> + errno = 0;
> sc = clock_getres( (clockid_t) -1, &tv );
> puts( "Init: clock_getres - EINVAL (NULL resolution)" );
> + errno = 0;
> sc = clock_getres( CLOCK_REALTIME, NULL );
> @@ -196,6 +218,7 @@ static rtems_task Init(
> tv.tv_sec = 0;
> tv.tv_nsec = TOD_NANOSECONDS_PER_SECOND * 2;
> puts( "Init: nanosleep - EINVAL (too many nanoseconds)" );
> + errno = 0;
> sc = nanosleep ( &tv, &tr );
> @@ -204,6 +227,7 @@ static rtems_task Init(
> tv.tv_sec = -1;
> tv.tv_nsec = 0;
> puts( "Init: nanosleep - negative seconds - EINVAL" );
> + errno = 0;
> @@ -212,6 +236,7 @@ static rtems_task Init(
> tv.tv_sec = 0;
> tv.tv_nsec = -1;
> puts( "Init: nanosleep - negative nanoseconds - EINVAL" );
> + errno = 0;
> 2.16.4
> devel mailing list
> devel at rtems.org
