[PATCH 3/3] c-user: Split deprecated/removed directives chapter
Tue Apr 14 15:13:22 UTC 2020
 c-user/task_manager.rst | 11 +++++++----
 1 file changed, 7 insertions(+), 4 deletions(-)
diff --git a/c-user/task_manager.rst b/c-user/task_manager.rst
index aca3699..c3919f4 100644
--- a/c-user/task_manager.rst
+++ b/c-user/task_manager.rst
@@ -600,7 +600,7 @@ against the current system configuration.
 .. index:: rtems_task_get_note
 .. index:: rtems_task_set_note
-Transition Advice for Obsolete Notepads
+Transition Advice for Removed Notepads
 Task notepads and the associated directives :ref:`rtems_task_get_note` and
@@ -618,7 +618,7 @@ also possible that thread-local storage (TLS) is an option for some use cases.
 .. index:: rtems_task_variable_get
 .. index:: rtems_task_variable_delete
-Transition Advice for Obsolete Task Variables
+Transition Advice for Removed Task Variables
 Task notepads and the associated directives :ref:`rtems_task_variable_add`,
@@ -1757,8 +1757,8 @@ NOTES:
     visitor, however, take care that no deadlocks via the object allocator lock
     can occur.
-Deprecated and Removed Directives
+Deprecated Directives
 .. raw:: latex
@@ -1800,6 +1800,9 @@ NOTES:
     control block may be in an inconsistent state or may change due to
     interrupts or activity on other processors.
+Removed Directives
 .. raw:: latex
    \clearpage
2.16.4
