[PATCH 3/3] c-user: Split deprecated/removed directives chapter
Gedare Bloom
gedare at rtems.org
Wed Apr 15 13:55:33 UTC 2020
thanks, make the minor typo corrections and push
On Tue, Apr 14, 2020 at 9:13 AM Sebastian Huber
> c-user/task_manager.rst | 11 +++++++----
> 1 file changed, 7 insertions(+), 4 deletions(-)
> diff --git a/c-user/task_manager.rst b/c-user/task_manager.rst
> index aca3699..c3919f4 100644
> --- a/c-user/task_manager.rst
> +++ b/c-user/task_manager.rst
> @@ -600,7 +600,7 @@ against the current system configuration.
> .. index:: rtems_task_get_note
> .. index:: rtems_task_set_note
> -Transition Advice for Obsolete Notepads
> +Transition Advice for Removed Notepads
> Task notepads and the associated directives :ref:`rtems_task_get_note` and
> @@ -618,7 +618,7 @@ also possible that thread-local storage (TLS) is an option for some use cases.
> .. index:: rtems_task_variable_get
> .. index:: rtems_task_variable_delete
> -Transition Advice for Obsolete Task Variables
> +Transition Advice for Removed Task Variables
> Task notepads and the associated directives :ref:`rtems_task_variable_add`,
> @@ -1757,8 +1757,8 @@ NOTES:
> visitor, however, take care that no deadlocks via the object allocator lock
> can occur.
> -Deprecated and Removed Directives
> +Deprecated Directives
> .. raw:: latex
> @@ -1800,6 +1800,9 @@ NOTES:
> control block may be in an inconsistent state or may change due to
> interrupts or activity on other processors.
> +Removed Directives
> .. raw:: latex
> \clearpage
> 2.16.4
> devel mailing list
> devel at rtems.org
